#41 |
To some extent, it may be simpler to list the one that won't work. Do you have measurement capability?
The W4-1337SD is outstanding in the midrange but does require a notch filter to control the break-up. The bamboo drivers are nice and have less breakup to deal with. The W4-1052 has shown to be admirable if you don't mind a minor drop in output above 15kHz. There is a new one available to us in the States that looks very intriguing, W3-1401D. Of course, I will once again plug the Mark Audio CHR-70. It is wonderful and just as cheap as the better TBs.
John |
#42 |
I'm afraid that it is very slow progress at my end in terms of a FAST speaker design and now that it's holiday season ...
Anyway, looking at the miniTysen 0v7 design it is the Full-range driver that gets the TL treatment with the woofer in the sealed cavity. This is the opposite way around to what I had expected - where the woofer would enjoy TL loading for extended bass and the full-range would sing nicely in a sealed box. I see an issue that for the TL for a woofer means lower frequency which drives a longer line and so it implies more box volume to get enough folded TL length - what are your thoughts ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#43 | |
Well, if that's open to the floor, the specific drivers were chosen for synchronistic performance: 1) we're big fans of the the SDX7, and chose it precisely because it works very well in small sealed enclosures (indeed, if using a single as a powered sub, the funnest part can be getting some plate amps to fit in the same box) 2) as Dave posted earlier, the TL was chosen for the FF85K (another driver on our personal "short list") to smooth its operational impedance load http://www.diyaudio.com/forums/showt...52#post1827952
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#44 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#45 |
Thanks guys, that's very helpful and give me a bit more food for thought. I guess a sealed box is also better suited for EQ as well, providing there's enough Xmax.
#46 | |
Cheers! |
#47 |
Here's a question, Dave - would using two woofers (shallow mounting) magnet to magnet be better?? - you talked of colouration, and having a woofer at each side of the box would stop the box vibrating... provided there's enough bracing.
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#48 |
frugal-phile(tm)
A pr of push-push woofers would certainly have advantages.
To keep the current size they'd need to be smaller & quite shallow). A pair of Silver Flute W14s are too deep for instance. dave
#49 | |
http://www.acousticdev.com/cms/index...ized&Itemid=60
#50 | |
We could practically do a desktop Tyson with them ![]() Cheers! |
| 300B Set amp some variations | MartinV56 | Tubes / Valves | 0 | 12th February 2008 09:22 PM |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Zen Variations 5 | Nelson Pass | Pass Labs | 66 | 5th August 2003 04:57 PM |
| Zen & Zen Variations-Part.2 | billy | Pass Labs | 1 | 7th August 2002 06:24 PM |
| Zen Variations 3 - Questions | vpharris | Pass Labs | 0 | 22nd May 2002 07:08 PM |
