#21 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#22 | |
Aside from the observation that those are dangerously high SPL's, and personally don't make sense for any domestic situation I've ever encountered, I'd suggest that for a system with these capabilities, you'd need to look at professional PA gear. Our friend Mr Weldon might well have some suggestions, but it's probably safe to say that the components and enclosures wouldn't be tiny.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#23 |
http://creativesound.ca/details.php?model=MT27KITA
A bookshelf kit, available from css, duh. Im sure most people know about it, but anyways i thought it was worth a discussion. Atleast the drivers it utilizes are. |
#24 | |
I like to crank it sometimes when I'm feeling good you know like it's party time.I wouldn't label 105 dB/m dangerous... IMO the short term transients are less than some everyday industial environments (think big saws/planers and nail guns). Like I said I just really want to know if they can keep up with a good 7" and 1" dome that's all. No PA needed thanks.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#25 | |
frugal-phile(tm)
dave
#26 |
Hoping there's a pair @ this yrs. 'fest!
Don |
#27 | |
105 dB by looking at what the 10" peerless can do at Xmax, so with baffle step the mid/tweet s/b around 100 dB on paper. But I run stuff hotter than the limits Unibox gives but really depending on the musical content. So subjective opinions would be useful by experienced buiders I think. I normally use morel/dynaudio 28mm ferrofluid tweets and a usher 7" midbass.
#28 | |
http://www.gcaudio.com/resources/howtos/loudness.html sorry, but this is a bit of a pet peeve of mine, so here goes: I've worked in an industrial woodworking shop for over 15years with virtually every type of heavy equipment and hand held power tool you're likely to find. 8 hours of exposure to in excess of (measured) 95dBA is freaking loud, even with custom molded hearing protection. We get our hearing tested every year for WCB, and while the degree varies among individuals ( age certainly being a contributing factor ), no matter whether it's old guys like me (58) or the young-ens (18yrs), after the second year, there is almost universal pattern of increasing deterioration in overall sensitivity, low level acuity and high frequency response. Furthermore, in my own case, the exposure has precipitated and exacerbated non-stop tinitus, which can vary in intensity and pitch or beating. You can listen through it to a degree, but not without fatigue. No doubt a PA, home or car audio system can be assembled that attains or even surpasses the 120dB levels without gross levels of distortion, but that doesn't mean prolonged exposure is safe or sane. when it's gone, it's gone sorry, rant off As for " keeping up with a good 7" (mid/bass) and 1" dome ", it's probably safe to say that's very subjective. The lack of XO networks in the most critically sensitive range of the telephone band is a major advantage that a "good" single driver or FAST system can have over the more conventional multiway. For many listeners, what the simpler systems lack in brute strength and extreme extension, they more than make up in terms of intimacy, micro-dynamics, inner detail and texture, soundstage dimension, to name a few aspects of the musicality of the event for which there are no standardized metrics. Hell, the same could be said for the magic dance that some of us feel between a 3 watt DHT and high efficiency single driver BLH, but that's another can of worms that needn't be opened today....
#29 | |
frugal-phile(tm)
dave
#30 |
Dave,
I'm exploring two options that may end up being similar. One option is a PMC DB1+ clone [Clone of PMC DB1+ ???] Second option is a modified Tysen. By modified I mean I'd like to fold the TL to make a smaller table-top or stand-mounting speaker. In the end, the difference between these options may be down to a choice of XO frequency and front vs side mounted woofer. What's your advice, opinion etc. on comparing these options ???
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
| 300B Set amp some variations | MartinV56 | Tubes / Valves | 0 | 12th February 2008 09:22 PM |
| How fast are 'Fast Fuse' and how to identify? | bigpanda | Solid State | 7 | 22nd March 2005 09:00 PM |
| Zen Variations 5 | Nelson Pass | Pass Labs | 66 | 5th August 2003 04:57 PM |
| Zen & Zen Variations-Part.2 | billy | Pass Labs | 1 | 7th August 2002 06:24 PM |
| Zen Variations 3 - Questions | vpharris | Pass Labs | 0 | 22nd May 2002 07:08 PM |
| Page generated in 0.13194 seconds (82.06% PHP - 17.94% MySQL) with 11 queries |
