A thread for Tysen and variations on FAST
Old 14th May 2009, 07:11 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default The Visit
Originally posted by planet10
(JesseG borrowed them, took them up to Alert Bay with the "threat" that i may never see them again )
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th May 2009, 09:45 PM   #12
infinia is online now infinia  United States
infinia's Avatar
Hi
I think I would like to try something like those ie a small full ranger as a mid/tweeter and a helper woofer.
But then it mostly would be a tweek fest with room placement and setting amp levels crossed highish at 333 Hz with the side firing woofer? I'm sure it could be sweet once dialed in tho.
Any tips on a current Parts Express/Madisound full ranger driver to go with a sealed Morel 8" or ported peerless 10" woofer. TIA
Old 14th May 2009, 11:10 PM   #13
chrisb is offline chrisb
Originally posted by infinia
Hi
Did you have a particular FR driver in mind? FWIW, the choice of FF85K for this project was serendipitous, but not happenstance. This is one of the more under-rated little gems in the Fostex line-up.
For those with another taste (i.e. non-paper) , the Mark Audio CHR70 or Alpair 5 would be great candidates for this application, and no doubt any number of Tang Band drivers as well.
As for the tweek-fest, isn't that why we're DIYers? - any idiot could just buy a B0$e lifestyle system and be done with it
kinda burnt out - taking a break
Old 15th May 2009, 12:09 AM   #14
HareBrained is offline HareBrained  United States
HareBrained's Avatar
I can second the CHR70. It's an excellent value. A driver this cheap shouldn't sound this good. It also can handle 20W without a problem (and that should be ~60W if Fc>300Hz.)
Old 15th May 2009, 02:37 AM   #15
Bigun is offline Bigun  Canada
Bigun's Avatar
Dave,
I'm glad you've started this thread, long overdue if you don't mind me saying.
The Tysen was the one that got me thinking CSS drivers and some low end assistance for my MoonOnkens.
At some point this year the 'itch' to build speakers again will likely pull me back. I am leaning towards the Tysen sytle approach. But I want physically smaller boxes. I'll be keeping an eye on this thread to see how these things develop
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 15th May 2009, 03:16 AM   #16
infinia's Avatar
No , just something that can do high SPL's ie at least 105dB/m steady and w/o sounding compressed when pushed with transients of 10 -15 dB more.
I guess what I'm really asking is...
Beside a different/sweeter SQ than the ubiquitous 7" midwoof and dome two way's could these things hang when pushed hard.
Based on the larger helper woofers listed in my above post.
Old 15th May 2009, 03:55 AM   #17
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
Default Re: The PLLXO
I'd love to know the values for that non-buffered PLLXO, I'm thinking I may try this with my FE126E/W15 FAST. The current cross is 200Hz and even though it sounds unreal the crossover should be a tad higher. I'd love to build this curcuit into my interconnects to bi-amp with my LM3875 GC's, seems like it could easily fit into the braid of some Techflex, Hmmmmmm...... You have me thinking now Dave.... Very Dangerous it seems as of late for me to think at all LOL....
If you can think of the values I'd love to hear them Dave, Peace and keep well.
[i]
I thot i'd done a map of the XO, but i've not been able to find it... i may only have sketched it on paper.
dave [/B]
What was that?... I can't hear you I have a line array filling my ears.
Old 15th May 2009, 06:31 AM   #18
frugal-phile(tm)
planet10's Avatar
Default Re: Re: The PLLXO
The values i used would probably work for the bass amp (10k, 0.1uF IIRC), but you are going to have to get creative to do 2nd order on the hi-pass as the input R on a gain clone is (usually) too low. what you will probably have to do is make the high pass gainclone into a 2nd order powered filter -- shrink the input C to move that pole up to where it needs to be, and then another C in the feedback loop for the other pole. Time to dig out the active filter cookbook.
dave
Old 15th May 2009, 03:24 PM   #19
ped is offline ped  United States
At the risk of a bit of noise couldn't the Zin of the GC be changed to 100k with a few resistor swaps?
And btw, what does FAST stand for?
Old 15th May 2009, 03:54 PM   #20
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Fullrange And Subwoofer Technology
planet10 needs your help:
Let's help Ruth and Dave
A thread for Tysen and variations on FASTHide this!Advertise here!
300B Set amp some variations MartinV56 Tubes / Valves 0 12th February 2008 10:22 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 10:00 PM
Zen Variations 5 Nelson Pass Pass Labs 66 5th August 2003 05:57 PM
Zen & Zen Variations-Part.2 billy Pass Labs 1 7th August 2002 07:24 PM
Zen Variations 3 - Questions vpharris Pass Labs 0 22nd May 2002 08:08 PM
