A thread for Tysen and variations on FAST
Old 27th October 2009, 06:12 PM   #121
chris661 is offline chris661  United Kingdom
chris661's Avatar
Ok, thanks for that - going to go swap the cabs over, see if I notice anything...
Chris
My work: www.grimshawaudio.com
Old 29th October 2009, 02:32 PM   #122
ljfont is offline ljfont  Canada
ljfont's Avatar
Originally Posted by planet10 View Post
Bessel = 1/2 cubic ft
Butterworth = 1/4 cubic ft
I like to use 14-17 litre
dave
Changing the volume, changes the Q. But how does it really sound?
This question might be opinionated, but how would you correlate Bessel or Butterworth to how the low frequencies sounds? Tighter, Fatter, Rounder, etc.
Thank You.
Old 29th October 2009, 07:21 PM   #123
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The lower Q boxes give a more even tighter bass, at least in my room, better matching the room gain, but this is so room and placement sensitive as to be very tentative. Most plate amps also have some ability to add bass boost, so a lower Q box gives more flexibility.
Effective box size can also be changed within reason with the amount of stuffing in the box.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 29th October 2009, 08:46 PM   #124
ljfont's Avatar
Default Adjustable Q?
With the amount of space left in this prototype. I was thinking about adding something to adjust the Q for the SDX7. Perhaps shelves that could be slid in and out to reveal another sub chamber to increase the volume. Not sure how to do it, it may require some tricky woodworking skills.
Should I start a separate thread for all of this?, I'm getting close to a prototype build.
Old 29th October 2009, 08:49 PM   #125
ljfont's Avatar
See Drawing. O yeah, currently the middle area hiding the BSC and/or networks.
Old 29th October 2009, 08:54 PM   #126
frugal-phile(tm)
planet10's Avatar
For the variable volume SDX7 part yes... people will be interested in that separatly from FAST.
dave
Old 8th November 2009, 07:54 PM   #127
ttsto is offline ttsto  Romania
Hi Dave and all contributing to this thread
I have interst also in building such enclosure, probably startig from FE167E or even FE207E.
I would like to uderstand more on what characteristics the woofer should be selected to best match the full-range driver.
Thank you
Old 8th November 2009, 10:24 PM   #128
frugal-phile(tm)
planet10's Avatar
A woofer with an extended range and a similar kind of character really helps when trying to get them to integrate. If you are going to attempt a passive XO, the woofer should be at least 3 dB higher than the FR.
dave
Old 9th November 2009, 05:53 AM   #129
Dave, thank you for the response
Unfortunatelly I do not have your experience, so "similar character" does not really ring a bell to me...can you be more specific?
Thanks!
Old 9th November 2009, 04:44 PM   #130
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
passice-active crossover, Since i am doing this, one amplifier per speaker, want to lend a hand with helping me with mine ?
pretty simple to do, just need a start with values, sent u a email but not sure ur getting them.
Living room looks awesome dave
A thread for Tysen and variations on FASTHide this!Advertise here!
300B Set amp some variations MartinV56 Tubes / Valves 0 12th February 2008 09:22 PM
How fast are 'Fast Fuse' and how to identify? bigpanda Solid State 7 22nd March 2005 09:00 PM
Zen Variations 5 Nelson Pass Pass Labs 66 5th August 2003 04:57 PM
Zen & Zen Variations-Part.2 billy Pass Labs 1 7th August 2002 06:24 PM
Zen Variations 3 - Questions vpharris Pass Labs 0 22nd May 2002 07:08 PM
