Old 5th May 2009, 08:45 PM   #1
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
Default Horn for Neo hot spot
This driver seems to model exceptionally well in a rather small horn design. http://www.mcmelectronics.com/produc...S5N-8-/55-1906. Here's my drawing.
PASSIONN
Old 5th May 2009, 11:16 PM   #2
GM is offline GM  United States
GM's Avatar
Your link appears to be no good, but if you mean this one, then based on some measured specs it's HF mass corner is much too high for me, though some of the Lowther folks don't seem to mind such high acoustic XOs.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th May 2009, 11:44 PM   #3
Scottmoose's Avatar
Heck, I make that up around 619Hz per Keele. Too high for my taste.
Old 6th May 2009, 12:51 AM   #4
brsanko's Avatar
Well I guess I don't know what that means.
PASSIONN
Old 6th May 2009, 12:58 AM   #5
brsanko's Avatar
Oh yeah I forgot to post my hornresp data.
PASSIONN
Old 6th May 2009, 03:00 AM   #6
Check out GM's post here: http://www.diyaudio.com/forums/showt...79#post1643579
Old 6th May 2009, 05:26 AM   #7
brsanko's Avatar
GM
Yes that's the one.
PASSIONN
Old 6th May 2009, 08:15 AM   #8
Scottmoose's Avatar
Hmm. Even using Qe rather than Qt, it's still up around 394Hz. High.
Old 6th May 2009, 05:52 PM   #9
GM's Avatar
FWIW, it's ~403 Hz with the measured specs I have. BTW, Qts is the most correct value to use for calculating the mass corners and what sealed, ported box design is based on, but for horns we're mostly interested in a driver's effective motor strength, which is Qes.
Since the majority of the math side of my design knowledge was 'distilled' by the pioneers of audio, Altec and later, Prof. Leach, I wasn't aware of Keele's formulas until they cropped up on the Sound Practices list (AKA joelist), so never having compared the two, not sure if there's any audible difference with typical point source drivers meant for simple box loading, though for horn drivers (low Qms) such as the Galaxy, there's enough of a difference that AFAIK a person would have to be tone deaf to phasing issues not to hear it.
GM
Old 8th May 2009, 03:16 AM   #10
brsanko's Avatar
could you tell me in simple terms what effect that would have on the sound. I plan on reading up on this but I haven't been feeling good and have a pounding headache at the moment so I'm not really in the mood to do a bunch of reading. Don't mean to be a PITA but I would appreciate it alot.
PASSIONN
WTB: K2r Spot Lifter (in Canada) Nixie Swap Meet 0 15th January 2006 09:06 AM
What does YOUR computer spot look like? Circlotron Everything Else 250 23rd February 2005 07:55 PM
A spot here for posting PCB files??? Mark A. Gulbrandsen Pass Labs 0 19th February 2002 04:07 AM
Page generated in 0.13445 seconds (67.73% PHP - 32.27% MySQL) with 11 queries
