Old 8th May 2009, 03:55 AM   #11
GM is offline GM  United States
GM's Avatar
Hope you get to feeling better, I suffer from migraines that can immobilize me, so 'feel your pain'.
Anyway, if you design the BLH to cover the driver's rising response BW, then the higher the mass corner is the longer the horn's path-length must be for a given Fc and at some point the time lag between the horn's and driver's output becomes audible, 'smearing' their overlapping BW (acoustic XO).
Different folks have different thresholds for noticing and/or find this time 'smear' irritating, but a good rule-of-thumb (ROT) is to have the acoustic XO no higher than ~250-400 Hz depending on how sensitive the listeners are to it, ergo ideally its effective mass corner will be the same. Since I fall into the < ~250 Hz group, this driver is unacceptable to me and if you have a variety of listeners, then best IMO to err on the low side of caution when choosing an effective mass corner.
It's this latter criteria that gets many folks into trouble, i.e. they design a BLH based on its T/S specs, then drive it with a high output impedance that's significantly increased Qes, lowering the mass corner, so the whole horn is now too small.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 8th May 2009, 04:01 AM   #12
brsanko is offline brsanko  United States
brsanko's Avatar
Send a message via MSN to brsanko
According to hornresp the XO would be at about 350hz, is this inacurate?
PASSIONN
Old 8th May 2009, 04:18 PM   #13
GM's Avatar
I haven't inputted your design or messed with the CH option yet, but the deep notch appears to be at ~400 Hz in the shadow response plot.
GM
Old 8th May 2009, 07:12 PM   #14
brsanko's Avatar
Ok I see what you mean. I guess I haven't listened to any designs with the crossover that high so I have no idea if it would bother me or not. It's just such a small easy to build design it's so tempting, But if the drivers aren't going to work at all in a horn design if I don't like it that's $80 down the drain. Hmm what to do. Do you think the effect would be less bothersome in a rear and surround speaker?
PASSIONN
Old 9th May 2009, 01:38 PM   #15
GM's Avatar
Don't know for sure, but due to the fact that when properly set up the sum of all the surround channels should = one main's output, then surround effects will be at least -3 dB (half power) in amplitude, so you're going to be concentrating on the mains output and more importantly, the video, which causes your brain to 'hear' what you're seeing.
Factor in that surrounds act as one only for LFE special effects AFAIK and I doubt anyone would notice it even if it was in our most acute hearing BW. I mean our internal processor can compensate for gross timing errors (or create them) when sight is added to the 'mix'.
Listening to 5.1 music without the video is an altogether different matter since we have to reconstruct the event using only a heavily processed recording of it played back through a typically high distortion system if other than headphones. Indeed, it's the various distortions that gives us the 'flavor' of the event, so it's a fine line between 'Heaven' and 'Hell', ergo 'God' is in the balance of the details and just like with religion there's no one true one for everybody.
GM
Old 9th May 2009, 04:32 PM   #16
gychang is offline gychang  United States
Apa's DIY
Default nice cabinet
interesting design if the math/physics work out.
gychang
WTB: K2r Spot Lifter (in Canada) Nixie Swap Meet 0 15th January 2006 09:06 AM
What does YOUR computer spot look like? Circlotron Everything Else 250 23rd February 2005 07:55 PM
A spot here for posting PCB files??? Mark A. Gulbrandsen Pass Labs 0 19th February 2002 04:07 AM
Page generated in 0.10021 seconds (80.89% PHP - 19.11% MySQL) with 11 queries
