#11 |
good luck!
http://www.hm-moreart.de |
#12 |
Looks like a cool project!
#13 |
the middle row of charts shows the response of both horns working together. The one on the right doesn't look really impressive by itself but when you consider that hornresp doesn't model the high frequencies of the driver correctly because it assumes a flat plane insted of a cone with a whizzer. If you look at how it plots the high frequencies in an open baffle compaired to how it plots it in the horn (middle left) you get a pretty good idea what it does for the high frequencies. As you can see by the plot it's bringing the spl up pretty evenly all the way up and if the true response of the driver is relatively flat then the response of the driver in the horn will be as well. This sounds like a leap of faith but we've done it several times and have found this to be quite true.
PASSIONN |
#14 | |
i'd like to see the updates when they're ready. |
#15 |
making it wider won't bring the bass lower for that it needs to be longer.
PASSIONN |
#16 |
how much larger would it need to get for that kind of lf resp.?
#17 |
How low do you want to go?
PASSIONN |
#18 |
40hz-45hz would be good.
#19 |
have there been any update of the plans, i.e. slightly larger for more bass and measurements/cut angles?
#20 |
almost 1300 views, lots of interest... I know I am. It will probably be between this one and the Hiro.
thanks for sharing paba |
| akabak script for compound horn | jbell | Subwoofers | 8 | 20th October 2010 06:05 PM |
| Filtering a full range compound horn? | brsanko | Full Range | 21 | 29th March 2009 05:16 PM |
| Bad Horn, Good Horn: FE164 -> FE166ES-R | rjbond3rd | Full Range | 2 | 22nd June 2008 03:02 AM |
| FE166es-r horn enclosure | jeremyg | Full Range | 5 | 18th December 2005 04:22 PM |
| Page generated in 0.08777 seconds (79.86% PHP - 20.14% MySQL) with 11 queries |
