Old 22nd April 2009, 06:45 AM   #21
chris661's Avatar
Looked around - next one down from the frs 8 is the fr8 - no significant changes, but it's cheaper over here...
http://cpc.farnell.com/visaton/fr8-2...ohm/dp/LS01668
Other than that, there's the ones they use in cheap Ghetto Blasters
http://www.maplin.co.uk/Module.aspx?ModuleNo=31433
Or eliptical ones, which would probably mean you can try different dimensions....
http://www.maplin.co.uk/Module.aspx?ModuleNo=3277
These speakers should be easy to get hold of, as they are used almost everywhere in cheap sound applications.
The middle link may be best: 99dB/W/m, +/- 3dB
Not gonna get much better efficiency than that...
However, it is around 6" across - if you made the front a 6.5" square, would that be Ok???
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 22nd April 2009, 06:57 AM   #22
http://www.zaphaudio.com/audio-speaker18.html
Old 22nd April 2009, 07:23 AM   #23
frugal-phile(tm)
planet10's Avatar
I can pretty much guarantee that is a typo... should be 89 +/- 3 dB and more likely on the - side of that. Certainly in the range for a 4" driver/
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th April 2009, 07:10 AM   #24
chris661's Avatar
Probably - seemed far too much
However, it looks similar to a friend's cheapo ghetto blaster, which goes pretty loud for 2W rms total.
Old 27th May 2009, 02:37 AM   #25
i want to do a portable stereo with t amp and the HIVI bs3. was thinking of the spiral horn. was wondering if that combnition would good for outdoors like near the beach. most speakers get drowned out by the surf.
Old 27th May 2009, 03:05 AM   #26
Dayton rs 100-4 is pretty affordable and nice.
Old 27th May 2009, 08:36 AM   #27
Alex from Oz's Avatar
G'day internecine,
Here's one from Oz:
http://www.altronics.com.au/index.as...=item&id=C0626
Input Power: 8 Watts RMS
Max Input Power: 15 Watts
Impedance: 8 ohms
Resonant Frequency: 120Hz
Frequency Response: 120Hz - 20kHz
SPL (1W @ 1m): 95dB
Alex
Need cheap full range 5 inch Josh Lasserre Full Range 24 8th July 2011 05:55 AM
Full range driver recomendation for dual mono LM3875 gainclone? zebra100 Full Range 5 4th August 2009 07:23 AM
support for small full range Artmaster Full Range 8 20th November 2006 08:59 AM
Help selecting a small Full Range mimir Full Range 9 31st August 2005 05:41 AM
cheap full range driver A'af Full Range 4 30th December 2003 02:00 AM
Page generated in 0.09309 seconds (80.57% PHP - 19.43% MySQL) with 10 queries
