Old 18th April 2009, 10:54 PM   #1
aquapiranha's Avatar
Default FE206eN and Alpha 15 in OB?
does anyone have experience of these drivers together in an OB? or even if it is feasable?
If OK, what freq. would you be crossing over at? 200hz?
I already have plans for the 103E and Alpha OB I was planning on building, but just wanted to canvass opinion on the other option.
Many thanks!
Old 18th April 2009, 10:59 PM   #2
brookbh is offline brookbh  United States
I would think you would need 2 Alpha 15s to make up the difference in efficiency between the 103e and the 206en. Is this going to be passive or active, any eq?
Old 18th April 2009, 11:02 PM   #3
Scottmoose's Avatar
Right, unless you pad the 206 down, twin Alphas will be better. Hell, twin 15in bass drivers are always worth having anyway. Too much is good.
Old 18th April 2009, 11:07 PM   #4
Thanks guys. Scott, the drivers would be borrowed from the Sachiko's I built. Do you have a design for twin alpha's and a 206 in mind? I could always get some more...
Steve
Old 18th April 2009, 11:27 PM   #5
Scottmoose's Avatar
Not particularly, just philosophising (as I do) -when it comes to bass, the more units the better IMO. Bass is where the brute-force approach works. Should do OK on Martin's basic twin bass unit baffle; 40in x 20in, twin Alpha 15s, crossed 2nd order, low pass at 200Hz, high pass 500Hz.
Old 18th April 2009, 11:35 PM   #6
Thanks Scott, I take it you mean Martin J King? not sure what the crossover you talk about means fully though, guess I ned to learn!
Steve
Old 19th April 2009, 01:13 AM   #7
planet10's Avatar
If you want to XO passively and use little or no padding on the 206 you will need 4 woofers. It should kickass.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th April 2009, 04:22 AM   #8
So what does the actual 1w/1m efficiency of the Alpha 15 drop down to on a flat baffle, around 90db? or even lower
Old 19th April 2009, 06:42 AM   #9
dave
Dave, are you saying I would only need a filter on the bass side rather than the 206? that sounds like as you say is would rock. How would I do this for 2 bass drivers? I have a schematic for a filter for one, but not two?
So many questions I know, I really appreciate the help!
Steve
Old 19th April 2009, 06:56 AM   #10
planet10's Avatar
No. Just that if you want a passivce XO, and no resistor or L-Pad on the 206 you'd need 4 15s.
dave
Surplus FE206eN sale planet10 Swap Meet 11 28th July 2009 11:41 PM
F/S Alpha 15a nvrgdenuf Swap Meet 6 9th July 2009 01:20 AM
F/S (2) Alpha 15a nvrgdenuf Swap Meet 0 25th May 2009 07:30 PM
Alpha 5 CDP Help Please! Bazzman Digital Source 6 3rd March 2008 10:27 PM
Looking for CAL Alpha DAC - 18 Bit Maurizio Group Buys 0 23rd October 2004 11:35 AM
Page generated in 0.10496 seconds (75.10% PHP - 24.90% MySQL) with 11 queries
