#11 |
On the basis that if enough is sufficient then too much is just right, then I'd agree. That said, based on the average spec. for the 206eNs, 2 Alpha 15s should do an acceptable job on the aforementioned baffle with a 2nd order:
#12 | ||
I will keep an eye out for another pair of 15's, and look into how to wire them "2nd order" Many thanks guys, you two have always been helpful. Steve |
#13 | |
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#14 | |
Sorry Dave I am a noob and have no idea what that means. I was planning on driving the fostexs with my decware zen, and the bass drivers with maybe a chip amp. I know the bass will need some form filter. |
#15 |
Hey, I am also a newb.
* Over-excurse == cone travels too far, past the 1mm or so maximum excursion (xmax) that it's designed for. By putting the signal through a high-pass filter before it hits the FE206E, the Fostex will not bother trying to play those bass frequencies, and will more likely stay within its xmax unless you really crank it. * PLLXO == passive line-level cross over, e.g. a circuit between the preamp and the (two) power amps, as opposed to having the circuit at the speaker's input terminals (after the power amp). I would assume the goal is to make the most of a low-powered amp's precious wattage? You can also use (a) an ordinary crossover circuit, or (b) an active crossover, e.g. a rackmount pro audio device, or (c) in a pinch, cobble together whatever you have, e.g. there are ways to fake a crossover with a mixing board. |
#16 | |
dave
#17 |
Dave, pardon my ignorance but could you explain how the signal is split at the source to feed the two amps, e.g., the Zen for the Fostex and another amp for the Alphas?
#18 | |
Steve |
#19 | |
It just means you need to move the PLLXO in front of the Zen. You are already looking at a couple amps if you are considering a PLLXO. http://www.t-linespeakers.org/tech/f...ssiveHLxo.html dave
#20 |
Thanks again Dave. i have had a think and may want to use a plate / sub amp for the bass (which of course would have level /slope etc controls) and the Decware in front of the 206's. I will read the link you sent, it is about time I learnt!
Many thanks Dave. Steve |
| Surplus FE206eN sale | planet10 | Swap Meet | 11 | 28th July 2009 11:41 PM |
| F/S Alpha 15a | nvrgdenuf | Swap Meet | 6 | 9th July 2009 01:20 AM |
| F/S (2) Alpha 15a | nvrgdenuf | Swap Meet | 0 | 25th May 2009 07:30 PM |
| Alpha 5 CDP Help Please! | Bazzman | Digital Source | 6 | 3rd March 2008 10:27 PM |
| Looking for CAL Alpha DAC - 18 Bit | Maurizio | Group Buys | 0 | 23rd October 2004 11:35 AM |
| Page generated in 0.11893 seconds (77.05% PHP - 22.95% MySQL) with 11 queries |
