Old 18th April 2009, 10:07 PM   #11
brookbh is offline brookbh  United States
The 125fr and 125wrt are now $50 and $40 at creativesound.ca and have more designs floating around for them now.
Also they sell AC ribbons and their own line of ribbons.
Old 18th April 2009, 10:15 PM   #12
Scottmoose's Avatar
Why is it, I wonder, that people will insist on sticking drivers into boxes that aren't designed for them?
Q on the 103 is far higher than Fostex's claims BTW. The cabinet is also shortly being replaced.
Old 18th April 2009, 10:21 PM   #13
G is offline G  United States
G's Avatar
Because the driver they were designed for have a limited xmax and therefore are limited as to what kind of music can be played through them?
Originally posted by Scottmoose Q on the 103 is far higher than Fostex's claims BTW. The cabinet is also shortly being replaced.
Bigger or smaller?
Gavin
Old 18th April 2009, 10:40 PM   #14
Scottmoose's Avatar
That's because they were specifically designed for a limited range of music. If they don't suit, then I would suggest that a speaker more appropriate to the requirements is in order. Stuffing a different driver into a cabinet designed & voiced for the characteristics of a specific unit (which is not all T/S work, even when published specs owe more to reality than the works of Tolkien) is rarely a good idea.
Same size. FWIW Lotus, with the Mark Audio CHR-70 might suit you better. The driver's 4.5mm travel (one way) and frankly worrying on the VFM scale. Admittedly, the cabinet is a little deeper though -10in rather than 6.5in. It'll take a second driver per enclosure too if you feel so inclined, and need more dynamic headroom.
Old 19th April 2009, 02:38 PM   #15
G's Avatar
Hi Scott. I understand what you are saying. I can't use the CHR-70 because it doesn't have the sensitivity that I need with a small SE tube amp.
I guess I will just build a pair of Tabaqs which reportedly work well with the 1320. I do have a question though. If I were to build the Tabaq from 19mm MDF or ply instead of 12mm it will end up elongating the vent by about 7mm. What will that do to the tuning of the cabinet?
Gavin
Old 19th April 2009, 03:54 PM   #16
Scottmoose's Avatar
It'll lower it by a couple of Hz; probably not such as to be noticable.
Old 19th April 2009, 05:58 PM   #17
G's Avatar
Thanks Scott. BTW do you have any experience with the RT1C-A ribbon tweeter from HiVi that I mentioned earlier in this thread. I have read numerous times posts saying that the 1320 is a great driver but needs a tweeter crossed over high in order to really shine. I planned on crossing the tweeter over somewhere in the 16KhZ - 18KhZ rainge with either a cap or a second order xover. Do you have a opinion as to where I should start with the crossover and how steep it should be. Also how close to the driver should I mount the tweeter?
Gavin
Vampyr Cabs for Tang Band W4-1320SJ? G Full Range 6 20th March 2009 10:27 AM
TM design with FR125S + ND16FA Matthew P. Multi-Way 1 28th January 2009 03:48 PM
Peerless XXLS vs. Dayton Reference vs. Dayton Titanic MKIII ? wigginjs Multi-Way 6 3rd March 2008 08:56 PM
Dayton DA aluminum cone woofer + Dayton DC28f tweeter springy101 Multi-Way 7 15th March 2006 05:22 PM
Dayton 6" reference and dayton silk dome tweeter combo project...input? nerd of nerds Multi-Way 4 2nd December 2004 05:36 PM
Page generated in 0.09361 seconds (74.41% PHP - 25.59% MySQL) with 10 queries
