Old 16th April 2009, 06:17 AM   #1
Default fostex fe87 blh?
has anyone built the fostex horn for the 3 inch fe87? looks fairly simple to build.
Old 16th April 2009, 09:02 AM   #2
Scottmoose's Avatar
fe87e recommended back horn...
fostex recomended box fe87
Old 16th April 2009, 10:39 PM   #3
Default revisited.
Thanks Scott,
It seems so long ago that I was making those speakers, but looking back at it now I realize that I am still just as freaking crazy~! at least privately...
If I were to build them again, btw, I would stick with 15mm as per the plans or even down to 12 mm plywood for budget and smaller size. Make a removable panel where the binding posts go. This will allow you to tweak with damping material in that region.
Also, I must advocate finishing the inside and out. Try osmo poly x if you are into the easier side of an oil finish. That should change the damping requirements (in this case, at least). some people flat out "dope" the inside of a cabinet with something or another. everyone has their own recipe for their own sound and it is an area worth researching. read the sticky thread up top of the fullrange forum about it.
It is a difficult build for a beginner, btw. Make sure those parts are square, dude!
good luck!
-Clark
scott: PM, how are things lately with you? Out here we are thawed and shorts and t shirted - for the next 6 months!
Http://blumenstein-ultra-fi.com
Old 16th April 2009, 10:47 PM   #4
Scottmoose's Avatar
No worries Clark, good to see you around again. Loved those walnut sides (even if it wasn't ideal when it started pulling the ply about). Will get a PM over to you later
Scott
fe87 mods valleyman Full Range 45 26th August 2008 01:36 PM
fostex recomended box fe87 jonastus Full Range 10 17th December 2006 09:28 AM
WTB: a pair of Visaton B200 or Fostex F108ES or Fostex FE126e or Jordan JS92S Rafal Swap Meet 0 10th November 2006 02:35 PM
What diy class a amp to use for fostex fe87 in Buschhorn ovy Solid State 0 10th July 2004 06:13 AM
Class a amplifier for fostex fe87 ovy Solid State 0 7th July 2004 06:32 AM
Page generated in 0.07363 seconds (74.38% PHP - 25.62% MySQL) with 10 queries
