Old 15th April 2009, 02:45 PM   #11
RJBond, that's very helpful and leaves me a bit puzzled: The stated F0 of a Lowther DX4 is 36hz and the stated frequency coverage extends down to 30hz (so far, at least roughly so good), but in any implementation I’ve seen like the Medallion II that Lowther America sells, the rated response extends only down to 65hz (not as low in fact as some RLH speakers based on the 5” Lowther drivers). Can you help me understand this?
Old 15th April 2009, 03:25 PM   #12
Scottmoose's Avatar
There you're talking about combined systems, not just a driver.
a/ Just because a driver's Fs is at x Hz, that does not mean it will produce useable output all by itself down to that frequency. If it did, there woud be no requirement for cabinets.
b/ The published Fs of the Lowthers is generally wildly optimistic (read 'fictional') -double it & you're usually closer to the truth. Not that they're alone in that -they're not.
c/ Horn LF extension depends on the horn -the Medallions are not tuned especially low.
Old 15th April 2009, 03:36 PM   #13
Hi guys, I was composing this before I saw Scott's reply, but I'll add it anyway!
The Lowthers are fine drivers, but the factory specs must have been determined in a non-standard way because they don't match the measurements made "in the wild." Check out Martin J. King's measurements:
http://www.quarter-wave.com/Project04/DX4_Data.html
Maybe the measured frequency response doesn't extend all the way down to the factory-quoted Fs because the actual Fs is much higher than the factory figure.
Keep in mind that while a typical vented cab only goes down to about Fs, a really well-engineered cab can go lower. If I had the DX4, I'd be searching for those ultra-finessed cabs that go as low as possible. (I'd also maybe get corners!)
If you want to get the maximum from your DX4's, I recommend at least trying a setup like Mr. Bob Brines, using a computer streaming lossless audio with digital EQ into a nice DAC. I have heard it, and it's amazing, and I never heard the Lowthers sound better.
Old 15th April 2009, 04:19 PM   #14
Yeah, I wish I had corners, too I've never heard any of Bob Brines' speakers but I assume that the system you heard included a pair of his DX3- or DX4-based speakers. Do you think his cabs are exceptionally well engineered?
Old 15th April 2009, 04:54 PM   #15
Hi David, yes I think everyone who either owns, them, has heard them, or is familiar with the Martin J. King modeling software used to engineer them, would agree that they are exceptionally well-engineered cabs. Like all speakers, it takes some experimentation (e.g. with positioning) to get the results you want.
I have the Brines LT-2000's built from a flat-pak (by forum member Phil Townsend) and originally had the DX-3's, but subsequently swapped them out several times for different drivers (why not?)
If you go with digital EQ, you have a lot of flexibility with positioning because you can compensate for boundaries or the lack thereof (within reason of course -- using digital EQ to turn a Lowther into a woofer would not be wise, I'm sure everyone would agree).
Speaking of Lowthers, Mssr. Phil Townsend had a pair of PM6A's the other day, and the ultra-heavy frames on those drivers are positively industrial-strength.
In the right fine-tuned cab, with the right music, in the right room, they are easy to love in my opinion. But very often, they are used "raw" and that doesn't show off what they can do. They might be the most misunderstood and mis-used of all single drivers.
Old 17th April 2009, 09:10 PM   #16
Thanks for all your help with this, guys.
Resonance vs Time MaVo Multi-Way 2 8th January 2008 11:11 PM
OpAmp Resonance? Stew Digital Source 32 7th April 2007 07:59 PM
Resonance Frequency DR ANALOGUE Multi-Way 5 11th January 2006 07:49 AM
tonearm resonance Werner Rem Analogue Source 4 6th February 2005 09:12 PM
Crossover too near resonance? niacin Multi-Way 16 15th April 2004 03:32 AM
Page generated in 0.08835 seconds (76.37% PHP - 23.63% MySQL) with 10 queries
