#11 |
OK, so from the same Danish gentleman I suppose
Check out the thread from Audioasylum, some info on the box design recommendations |
#12 |
Yes, klonew.
Thanks, I'll take a look. |
#13 |
Ok..they finally got here and it turns out these are Flat 5A-II's (thanks to this Danish guy's completely inaccurate description). I don't really have the patience to go through returning these, so I guess I'll try them out.
GM, could you do your wizard thing and tell me if that Vas approximation would still be relevant? |
#14 |
So yours says Coral 5A II, 3W nomimal, 8W max....on the back as well?
Just tested mine recently and realized one of mine had some scratchy noise at low freqs...... Anyway, mine does look the same as Flat 5 from the front, it's just that the magnet surround is different, and doesn't say Flat 5 II, but 5A II instead... I will be interested to know any recommendation on the box design as well |
#15 |
Yep..sounds exactly like mine. They aren't a matched pair either..one says 3W nom./8W max and the other just says 8W max, but both say 5A-11 on the back. Very dirty too..need to paint over some rust.
![]() Best guess I can come up with so far (with no info at all other than 3W/8 ohms) is a 0.38 cu. ft. (10.83 l) or bigger box tuned to <67hz, assuming Qts is 0.4 and Fs is 70hz. But I still have no idea what I'm talking about. Have you seen any designs for the 5A-II on Audioasylum? |
#16 | |
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#17 |
See if these links help
http://db.audioasylum.com/cgi/m.mpl?...ghlight=cft&r= http://diyparadise.com/coral_enclosures.html |
#18 |
I have a pair of real Flat 5 II now.
The ones I got earlier as mentioned aren't exactly Flat 5 II. They have smaller magnet and coarser frame, etc, though the paper cone and cloth surround should be the same type.... ![]() BTW, suggestion on the enclosure, anyone? |
| Coral Flat 6B's. 2 pairs. | nodiak | Swap Meet | 1 | 11th March 2008 08:47 PM |
| Coral Flat 6 vs. FE167e ? | nodiak | Full Range | 0 | 27th November 2006 10:09 PM |
| Coral Flat 10 | albertli | Full Range | 16 | 3rd August 2006 03:07 PM |
| FS: Coral Flat 6B drivers | harryz | Swap Meet | 0 | 2nd August 2006 08:16 AM |
| coral flat 8 fullrange | then_dude | Full Range | 9 | 25th September 2005 11:33 PM |
| Page generated in 0.08032 seconds (85.98% PHP - 14.02% MySQL) with 11 queries |
