Coral Flat 5 t/s
Coral Flat 5 t/s
Old 9th April 2009, 10:35 AM   #1
ballsingtripp is offline ballsingtripp  United States
Send a message via AIM to ballsingtripp Send a message via MSN to ballsingtripp
Default Coral Flat 5 t/s
Hello
I've just bought a pair of Coral Flat 5's on ebay..does anyone have any t/s parameters? I was only able to find some info on the Flat 6's. Their DC resistance or a way to measure it would be especially helpful. Unfortunately I can't afford a woofer tester at this point.
File Type: jpg !bpysdbg!wk~$(kgrhgoh-csejlllvgm7bjzvy-6ccg~~_1.jpg (20.3 KB, 498 views)
Old 9th April 2009, 12:15 PM   #2
aroS3 is offline aroS3  Greece
Send a message via MSN to aroS3
Default Coral Specs
Not much...
Old 9th April 2009, 02:42 PM   #3
Ah..still helpful, thanks!
I'm not sure if these are II's or not..
Old 10th April 2009, 04:50 AM   #4
GM is offline GM  United States
GM's Avatar
FWIW, a starting point.............
Using the II's minimal specs and erroneously using Qo as Qts, then with Mo, Vas = ~12.97 L, ergo a max flat alignment is theoretically ~35.24 L tuned to ~51 Hz with a ~5.08" diameter hole if a 19 mm baffle is used.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th April 2009, 04:31 PM   #5
Hmm..wish I knew what I was talking about.
Is there a way to determine Vas from those specs?
Old 10th April 2009, 07:10 PM   #6
GM's Avatar
Not accurately, unless the Mo, Fs, effective radius specs are. As I said, I made some erroneous assumptions to derive what all I calculated, so I chose to assume Mo = Mms to calc Vas. FWIW, the calc'd Vas is within an acceptable range for the driver size, Fs.
WRT the box calc, I have some experience with the simple Qo calculations and since they're fairly accurate in the range around ~0.4 Qts, I chose to assume Qo = Qts figuring at worst, the box would be too big and/or tuned too low, so with a simple vent hole it would have plenty of tuning flexibility for optimizing it to suit your app. This assumes of course that I used the right specs for your drivers and they are accurate.
All thing considered, I doubt they're even remotely close, but I'd be surprised if you can't make the suggested box work and if turns out to be way too large (or too small, which I doubt unless driving them with a high output impedance amp) you can always make new ones, so suggest you just cobble one together from scrap or other cheap materials, even industrial strength cardboard. Just make sure there's no air leaks before each modification or the effort will be wasted.
Vas = 0.01*po*c^2*Sd^2/((2*PI()*Fs)^2*Mms)
where:
po = 1.21 Kg/m^3
c = 344.43 m/s
Sd in cm^2
Mms is in grams
Note that different programs tend to use different po, c values, so for best theoretical accuracy use the ones for the program.
Bottom line, you want accurate specs you'll have to measure them somehow, whether by someone else, use a woofer tester or do it 'long hand': http://www.diysubwoofers.org/measure.htm
GM
Old 11th April 2009, 12:51 AM   #7
I'm sure these won't be the last enclosures for these drivers, and I was planning on handling it like you said too, so some experimentation is fine.
Makes sense now..thanks for the help!
Old 11th April 2009, 01:40 AM   #8
GM's Avatar
You're welcome!
Please let us know what you wind up with.........
GM
Old 15th April 2009, 04:20 AM   #9
CFT is offline CFT  United States
I am interested to know too, I have a same pair as well
Mine have Coral 5A II, 3W nomimal, 8W max....on the back. (not sure if they are the Flat 5 II either )
I have tentatively made some mini OBs for them....eventually with active xo to be mated with 5" woofers on hand ...
Old 15th April 2009, 04:28 AM   #10
Haven't actually gotten mine yet, but I hope they can handle more than 3W.
The auction said 92dB 1w/1m...
Coral Flat 5 t/sHide this!Advertise here!
Coral Flat 6B's. 2 pairs. nodiak Swap Meet 1 11th March 2008 08:47 PM
Coral Flat 6 vs. FE167e ? nodiak Full Range 0 27th November 2006 10:09 PM
Coral Flat 10 albertli Full Range 16 3rd August 2006 03:07 PM
FS: Coral Flat 6B drivers harryz Swap Meet 0 2nd August 2006 08:16 AM
coral flat 8 fullrange then_dude Full Range 9 25th September 2005 11:33 PM
Copyright ©1999-2017 diyAudio
