Old 5th April 2009, 04:38 AM   #1
limono is offline limono  United States
Default speaker repair wizzard needed
OK !having spent all my money on EV , TAD , Lowthers I've got in my posession a pair of JBL LE8 (old rusty alnico mags) full range drivers with surrounds changed. Frankly, these are the best drivers I ever heard. Tonally, they smoked Enabled lowthers DX4's and nothing (maybe some vintage Tannoys I briefly heard years ago) comes close to my ears. There are two problems with them . Voice coils are partially shorted and both drivers measure 1.3 ,1.5 Ohm DCR . Painted aluminium dust cap was ,is, a little ringy.
Is there anybody who could for resonable (very) amount of money:
take them appart (I probably can do it ) check if the short in VC can be fixed
eventually rewind the VC (maybe even with silver wire ) ,try phase plug instead of alu dust cap (I intend to use a tweeter anyway) measure the speakers ,play with them as long as one pleases and send them back??
Regards, L
Old 5th April 2009, 10:08 PM   #2
Speakerholic
Cal Weldon's Avatar
Did they look anything like this?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th April 2009, 10:09 PM   #3
Speakerholic
Cal Weldon's Avatar
Old 5th April 2009, 11:15 PM   #4
Little better I don't expect miracles ,hehe
These are first (or one of the first) LE-8 .Your fine samples are I gues LE-8T.
They do play fine on mikro Watt level .
Old 5th April 2009, 11:22 PM   #5
Oh , I think I know what you're thinking .Is it possible??
Regards, L
Old 5th April 2009, 11:43 PM   #6
Speakerholic
Cal Weldon's Avatar
What I'm thinking is...
The price to recone made mine expendable. No one wanted to use anything but original parts and that would have cut way too far into the beer fund. I agree they are a great driver but honest to betsy these were going to cost 300USD each cone plus install and shipping. No, I gave them to charity.
The dust caps on mine were attached to the top of the coil so they got that extra bit of extension. Yes they were the LE8T. Thanks for the pic of yours.
Old 5th April 2009, 11:51 PM   #7
OK I thought that you still have them and since the cones are trashed the coils could be reused.I know that original recone kits are $$$ (if you can get them). Well time to prepare acetone and a razor blade
Best , L
Old 6th April 2009, 12:20 AM   #8
pinkmouse's Avatar
Try a hot air gun and palette knife first.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 6th April 2009, 02:42 AM   #9
Hot air gun to loose up suspension ? It's been 20 years since I repaired a speaker and I remember we usually soaked up suspension (upper and lower) with acetone and waited overnight to loose it up . Than mandrel with thin paper around matched to voice coil diameter. Than search for magnet wire...
Old 6th April 2009, 02:51 AM   #10
picopos is offline picopos  Portugal
picopos's Avatar
hey
probably was exposed to dc and if u still have a reading in impedance u r lucky as i would only open them and treat the coil...well i did it before with results ,they still work...
open them and keep posting,good luck
marco
SONY TA 70, repair help needed jojospecial Solid State 2 5th November 2008 08:15 PM
Teac LS500 speaker repair - info needed Brisso57 Multi-Way 1 5th September 2008 11:52 PM
repair akai am-49 help needed pavlos Solid State 14 1st October 2007 09:18 PM
Amp repair help needed. contaxchen Tubes / Valves 2 11th July 2005 09:22 PM
A Question for the Wizzard-Biamping The X Aleph macka Pass Labs 1 20th June 2004 01:42 AM
Page generated in 0.09725 seconds (76.57% PHP - 23.43% MySQL) with 11 queries
