Mark Audio CHR-70 Application Thread
Old 3rd February 2013, 09:18 PM   #821
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Personally i don't like anything larger than 9 litres for a reflex for these. The CGR CHR-Ken will accomodate the river on any face.
Frugal-phile | Box Library / Mark Audio
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd February 2013, 09:52 PM   #822
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Dave,
Did you get an early start at a Super Bowl party?
Bob
Old 3rd February 2013, 10:18 PM   #823
frugal-phile(tm)
planet10's Avatar
Nope. Just a sticky spacebar.
dave
Old 3rd February 2013, 10:25 PM   #824
Squeak is offline Squeak  Denmark
Squeak's Avatar
You boys might want to keep the intimate stuff to PMs? Sounds juicy though. ;-D
Old 18th March 2013, 04:25 AM   #825
SirByrd is offline SirByrd  United States
SirByrd's Avatar
Here is the final version.
Old 25th March 2013, 03:51 PM   #826
satx is offline satx  United States
Default MA chr-70 Semi F.A.S.T question
Hey guys, I'm not sure if I should post this here or start a new thread.
I have a pair of Chr-70 gen3's that I have had in a 9L BR. I am thinking of combining them with a small woofer in what may be termed a FAST system. My goals for doing this are to maintain or improve upon the extension that i get from the chr-70 while adding a bit more weight or impact from the larger sd of the new driver. I also want to relieve the chr from producing bass to see what comes of that. I would like to try the chr in sealed or an open back tunnel on the enclosure.
I envision the total enclosure increasing to ≤15L with about 10L for woofer and 5L for chr. After much searching and consideration, the drivers I have in mind are The Madisound Speaker Store and Visaton W130S-8 5" Woofer with Treated Paper Cone 8 Ohm 292-564
They each show decent extension and roll off characteristics in 10-11L in WinIsd. (I am trying to get acquainted with all the FRD Consortium stuff, but there is a learning curve) The price is about where I want to be for this experiment and the numbers look right. If I'm correct the increased sensitivity should provide a built in 2.5db baffle step?
I plan on crossing them around 200hz first order. Large coil on woofer and large cap on CHR. Not sure if I should cross higher, say 500hz for that built-in baffle step to work. I don't want to run a separate amp for each speaker, I want to keep it more like a typical 2-way.
Am I on the right track for meeting my not to lofty goals? Way off? Out of my mind?
Any help would be appreciated.
Thanks,
Evan
Old 25th March 2013, 06:49 PM   #827
juhomoil is offline juhomoil  Finland
Cool CHR-70 gen3 Boombox
Hi
I just wanted to show you my experimental project of using a pair of MarkAudio CHR-70's in a Boombox. This was my 3rd Boombox I have built.
Both elements are in 6,5 litres BR. I calculated vents with the winISD. The Box has a 5 Ah Lithium battery, but also possibility to use 230 VAC.
I think it sounds very good and the little T-amp ensures (2x12W), that the xmax of CHR's will not be exceeded.
(The heart blinks by the music.. )
Old 5th April 2013, 11:38 PM   #828
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
I have updated my 2009 Black Beauty design for the CHR70A:
http://www.diyaudio.com/forums/marka...or-chr70a.html
Old 15th March 2014, 08:23 AM   #829
Honkey is offline Honkey  Australia
Hi All. I just finished these CHR-KEN's with the Enabled Planet_10 Hi-Fi CHR-70.2's . I've been breaking them in and they've been playing at low levels for around thirty hours. This project was my second speaker build and my first with the Mark Audio drivers. They sound great with my Helder Hi-Fi TA2020 amp! Guitars and vocals are excellent and I was pleasantly surprised with the quantity of clean bass these boxes produce. I haven't had a chance to mitre the corners so the ports are currently 198mm long in lieu of 191mm. I hope that doesn't adversely affect the box tuning. I routed out the ports into the 18mm marine ply outer side panels & also made the boxes slightly narrower and slight deeper than the Planet_10 design but maintained the nominated cross sectional area and height. I also installed a 12x18mm wide strip of plywood to the back of the outer side panels to allow for the wool felt lining attached to the rear plywood panel (see last photo). This helps to keep the slot before the ports clear. I hopefully will get around to installing the internal bracing but I'm soooo enjoying listening to the speakers I'm afraid I may never do it!
A BIG THANK YOU to Dave and Chris (Planet_10 Hi-Fi) for your efforts and for supplying the design (and anyone else who helped)!
Regards, Richard.
Old 15th March 2014, 08:54 AM   #830
frugal-phile(tm)
planet10's Avatar
Richard,
Took you awhile
Longer vents will tune a bit lower.
dave
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 04:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 01:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 09:20 AM
