Mark Audio CHR-70 Application Thread
Old 20th February 2012, 12:54 PM   #791
KyleinCowichan is offline KyleinCowichan  Canada
KyleinCowichan's Avatar
It's speaker cloth stretched over some 1/4" bb plywood frames. I used spray glue for sticking them down and then brushed on silicone after trimming to keep the edges of the fabric from fraying. The back side of them looks far rougher than the front. They are held on with magnets sunk into the baffle.
Kyle
Old 20th February 2012, 12:57 PM   #792
Squeak is offline Squeak  Denmark
Squeak's Avatar
Are the frames prefab or did you make them yourself? I've been thinking about doing something similar myself but wasn't able to find suitable rings.
Old 20th February 2012, 01:48 PM   #793
I cut them myself with my router and jasper jig. It was quite easy, and the fit was perfect. Getting the fabric stuck on the backside evenly is the hardest part. You just have to patiently work it into place. I'll see if I can find some construction pics later.
Kyle
Old 20th February 2012, 03:17 PM   #794
GM is offline GM  United States
GM's Avatar
FWIW, embroidery hoops makes making round grills a fairly trivial procedure for the time and/or woodworking challenged.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th February 2012, 03:34 PM   #795
chrisb is online now chrisb
Originally Posted by KyleinCowichan View Post
By general consensus I mean that I saw Chrisb mention that in a thread.
Kyle
he's likely just repeating something he read on the inter-webs
like my mind, this space intentionally blank
Old 20th February 2012, 03:37 PM   #796
Old 20th February 2012, 04:09 PM   #797
skeeter99 is offline skeeter99  United States
skeeter99's Avatar
GM
Nice! That's a great tip, thanks!
Scott
Old 27th February 2012, 11:23 AM   #798
fakeout is offline fakeout  Canada
fakeout's Avatar
Does anyone know what the highest frequency is for the generation 1 and 2 of the Mark Audio CHR-70? I'd like a full range speaker without having the higher frequencies "piercing" my ears (fatiguing).
Old 27th February 2012, 11:41 AM   #799
lduarte1973 is offline lduarte1973  Portugal
Banned
Anyone used Alpair CHR-70 as midrange (250-10k) in a 3 way system ? sensivity is not a problem since i use minidsp (tri amp) and mid amp is 150w rms.
Old 28th February 2012, 01:15 AM   #800
jeeracing is offline jeeracing  Canada
just to show you what I did with my chr-70. in-cielling suround speaker for my HT, match with a cheap dayton ND20. the CHR is full range and the tweeter is cut with only a 1uF cap. "very good result". I luv it.
jee.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
