Mark Audio CHR-70 Application Thread
Old 14th April 2009, 01:56 PM   #71
italynstylion is offline italynstylion  United States
italynstylion's Avatar
I'm having trouble deducing the measurements of the little wedge that is located on the axis of symmetry on the back wall. Also, the internal brace is intentionally off center correct? I'd imagine that if the brace is on the left side of the center I'd put the second driver on the right side?
Old 14th April 2009, 03:43 PM   #72
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
That's because there aren't any on the plan. 1in deep, equilateral triangle. It isn't very big. Yes, the brace is slightly offset -away from the sideways firing driver is probably best, although there's very little in it. The brace is optional anyway, as these boxes are quite slim.
Depends on the sheet size -I usually work in 4' x 8', as that's what's most often found in the UK, and unless you pull some fancy stuff (by my standards -I'm the world's worst woodworker) you can't quite do it with that. But I think it might just be doable with 5' x 5'.
Old 14th April 2009, 05:07 PM   #73
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Default Lotus Spawn
So, I've had my CHR70s for a few days and I've been able to crank it a few times and I think this BVR may be ideal. The depth of bass from these drivers is incredible considering their size but the quality suffers a little in the BR. But the quality should improve in the Lotus. And two drivers could just be the best inexpensive speaker available (considering the BB ply is going to cost more than the drivers.) Thank you Scott and Dave for the design.
I noticed that the driver is only 26" from the floor. What would be a recommended way to raise this? Could front baffle be recessed making the height of the cavity longer (resulting in a C-shaped side panel and leaving the vents the same dimensions)? If internal depth is reduced to 5", it would raise the driver 10.5", and 6" would raise the driver 6.25".
One thing you should be aware of, the frame lip is 6mm (~.25") and it's not solid. Recessing the driver takes a considerable chunk out of the baffle. And although the drivers include a (thin) gasket, you may want to fill the back side of the frame flange to ensure it seals or use an alternative, thicker gasket, especially if your route was not smooth. Lastly, the mounting holes are small, #4 screws only. Two more mounting holes would have been nice. You may want to use a positive mounting system, like t-nuts. Fortunately, the flange is wide and leaves a good amount of material behind it. Some kinda supra- or double-baffle might be worthwhile, or surface mount on the baffle and use a 0.25" trim panel (fortunately, it's a common material thickness for lots of different woods.)
Old 14th April 2009, 05:35 PM   #74
chrisb is offline chrisb
Originally posted by Scottmoose
[B]That's because there aren't any on the plan. 1in deep, equilateral triangle. It isn't very big. Yes, the brace is slightly offset -away from the sideways firing driver is probably best, although there's very little in it. The brace is optional anyway, as these boxes are quite slim.
Depends on the sheet size -I usually work in 4' x 8', as that's what's most often found in the UK, and unless you pull some fancy stuff (by my standards -I'm the world's worst woodworker) you can't quite do it with that. But I think it might just be doable with 5' x 5'. ['/b]
not quite - actually with driver braces, etc, you'll be closer to 1 1/2 sheets at 5x5 ft
like my mind, this space intentionally blank
Old 14th April 2009, 05:56 PM   #75
Scottmoose's Avatar
Ah well. Can't have everything, right?
Re height, angle it backward. 3 - 4 degrees would be sufficient in most cases. You can't recess the baffle etc., or alter the shape of the driver chamber in any way without a total redesign.
Old 14th April 2009, 06:16 PM   #76
Yeah, I didn't think these would really need a brace but I was prepared to use one if you thought it was needed.
When you say 1" deep do you mean 1" from the base wall to the tip pointed at the rear of the driver?
Old 14th April 2009, 06:25 PM   #77
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Lotus Spawn
In practise this is not really a hardship. Listening a bit off-axis is often a good thing to avoid the beaming inherent in most FRs. And if you wanted the driver firing right at your head, it wouldn't take nuch of a lift of the front of the speaker to do so.
Further, discuaaiona with Chris on driver placement for a dual-driver version (Scott comment please), we will probably move the front driver up a half basket width, and the side driver down a half driver width so as to maintain Zd, keep the drivers close together, yet decrease the reflective surfaces of the back of the drivers away from the other.
When you consider the base we'll add + that change, driver height becomes 31".
The diagram assumes that a minimum stabilization base has been added.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th April 2009, 06:33 PM   #78
To yield from a single 4x8 sheet, you'll need to splice one of the back panels - I'd suggest behind the triangular deflector.
Regarding driver height, Dave will probably be revisiting driver placement and bracing configuration when using a side mounted second driver (a la Calhoun) .
edit: I note that while I was planning the cut sheets for the 2 material sizes, he did just that.
and yes, even with substantial ballast in the lower void, these will be very tippy, and some type of extended width plinth would be required.
Old 14th April 2009, 07:39 PM   #79
Scottmoose's Avatar
I can't think of any good reason why the slight shifting of the two driver positions you mention shouldn't work Dave.
Yes, they're going to need a wide plinth for stability. Sorry.
Old 14th April 2009, 08:47 PM   #80
Default Re: Re: Lotus Spawn
dave
Thanks for the responses. I should have realized a base would be needed (of course, I would have after building them. ) I rarely just sit and listen. I'm always moving around, but the "beaming" from the CHR70 isn't bad. You have to be a good angle off-axis to notice a drop in response. Certainly outside the "cone" illustrated by Dave. It'd be good to see some polar response charts for this driver.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
