Mark Audio CHR-70 Application Thread
Old 17th December 2010, 07:47 AM   #661
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Nice pipe!
Old 17th December 2010, 08:17 AM   #662
thunk303 is offline thunk303  Australia
thunk303's Avatar
That was the only tricky bit since I didn't want the drivers protruding outside the pipe circumference.
As you can see from the photos, i used a ply mounting plate and HEAPS of liquid nails, the dowels hold the whole deal in place with more liquid nails.
I then shaped the outer surface with Plasti-Bond, a kind of fiberglass/bog stuff.
These are 1200mm long and have a random exit throat size, because I have no idea how to use MJK's worksheets yet and just like building things.
Speaking of which Dave + other!!!
ATL?
Dean
Old 22nd December 2010, 10:58 PM   #663
nolby is offline nolby  Italy
How much power in watt needs an amplifier to drive nicely chr70 speakers?
Actually I use them with an amp ta2024 tripath chip, which is too weak (10w real). Do you think a ta2022 or tk2050 (both tripath 100w x2 4ohm) will bee fine?
Someone told me that for a speaker with impedance of 3,60 and efficiency at 84,5 I should use even more power.
Old 23rd December 2010, 04:44 PM   #664
chrisb is offline chrisb
too many factors to be considered, and there really is no single right answer - 100 "real" watts would be more than enough to hurt your ears and or the drivers
a lot of folks are quite happy with the quality of output from the CHR70 with as little as 10-12w of tube power (as we all know, they're "bigger" watts )
Old 23rd December 2010, 06:25 PM   #665
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Don (aka Doorman) is happy with 3.5.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd December 2010, 07:04 PM   #666
doorman is offline doorman  Canada
doorman's Avatar
dave
Don
Old 23rd December 2010, 09:02 PM   #667
dave
Originally Posted by doorman View Post
Don
but then he's a half deaf old fart like me who listens to only chicks and guitars and not very loud at that
now it's on ....
where's Cal to tell us how much is not enough?
who's been into the X-mas cheer and confections a bit early? - my head's gonna hurt later this evening
Old 23rd December 2010, 10:51 PM   #668
doorman's Avatar
now it's on ....
No argument from me, Chris! ( birth certificate says 65 in 2011)
The requirements for fullrangers pour moi ,are shrinking all the time- hearing impairment has its advantages!
Best, Don
Old 31st December 2010, 03:31 PM   #669
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Hey guys, just built these:
Here they are taped up with masking tape, to try to get an idea how much stuffing is necessary:
Once I make a finalized decision on the stuffing, and glue on the side wall, I'm going to add on a proper baffle to the front, so that the driver will be flush mounted, and so the grain of the plywood is covered up (and to add a roundover).
So far I'm pretty happy with what they can do at such a low price, and small form factor.
I will be using them as desktop computer speakers. So far I'm quite pleased, but I'm reserving final judgment for when I'm done. Very easy build (one evening's work).
Regards, James
Old 6th January 2011, 03:07 AM   #670
tommy_o is offline tommy_o  United States
I'm just finishing my budget, sealed CHR-70s and was wondering if anyone uses CAT5 wiring as speaker cables. I've seen TNT Audio writings on different configurations (for example, here) but does anyone have preference or practices they've used in the past? This would mainly be a temporary wire straight out of the enclosure and to my amp.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
Copyright ©1999-2017 diyAudio
