Mark Audio CHR-70 Application Thread
Old 11th April 2009, 06:46 PM   #51
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by italynstylion
Here is the dual driver BR bookshelf design....plan-chr70-till-2-70
That box could use some detail tweaking. And i'd mount the 2nd driver on the top or side.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th April 2009, 07:42 PM   #52
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Originally posted by planet10
Not necessarily too much power. Certainly too much gain. You need to sort that, down there is were volume controls are at their worst.
dave
I understand what you're saying. The GFA5400 is 2x125W and the preamp is scaled to get every watt at 10/10ths. I've never owned a set of speakers that could handle the full output. I actually have a pair of Pass Labs Zen v1 PCBs that I need to build. Do you think that might be a nice match for the CHR-70s?
Old 11th April 2009, 07:49 PM   #53
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yup.
Old 11th April 2009, 08:18 PM   #54
frugal-phile(tm)
planet10's Avatar
Originally posted by HareBrained
I actually have a pair of Pass Labs Zen v1 PCBs that I need to build. Do you think that might be a nice match for the CHR-70s? [
Yes, nicer than the Adcom
dave
Old 11th April 2009, 10:12 PM   #55
italynstylion is offline italynstylion  United States
italynstylion's Avatar
dave
What detail tweaking would you recommend? As for driver placement, what would be the differences between mounting the second driver on the top vs. on the side? I worried about there not being enough port area for the drivers but I wasn't sure if I was right about that. Also, their suggested filter on those plans, do you guys know what it does?
Old 12th April 2009, 07:03 PM   #56
dave
Dave,
What's your opinion of using a 1.5-way crossover for the dual driver arrangement? My understanding would be that a single coil between the series drivers would provide BSC (assuming the speakers are in needed) and a LP filter below the critical frequencies.
John
Old 13th April 2009, 04:06 AM   #57
brookbh is offline brookbh  United States
Does it not essentially create an almost 1.5 way if you simply mount the 2nd full range speaker away from the listening position, ie on the side or top as suggested?
Old 13th April 2009, 04:16 AM   #58
frugal-phile(tm)
planet10's Avatar
Yes, that is the idea.
dave
Old 13th April 2009, 06:45 AM   #59
frugal-phile(tm)
planet10's Avatar
I'd reorient the bracing... a shelf brace is the least effective. A brace should divide a panel into new subpanels with a higher aspect ratio.
Driver on the side wouldn't suffer from gravity, but in the end it depends on room placement. With careful consideration this box is small enuff to be converible.
dave
Old 13th April 2009, 04:05 PM   #60
From what you've mentioned, I think I'll opt for putting the second driver on the side.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
