#431 |
I am thinking of using autobody filler to fill any gaps and create an absolutely smooth surface for the veneering. Does carpenter's glue work well with this, or would you suggest wood filler?
any comments are welcomed. thanx
stew ☮ -"A sane man in an insane world appears insane." |
#432 |
frugal-phile(tm)
Chris uses bondo... he might have some tips.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#433 | |
Shane I guess there are really 2 parts to this answer, depending on 1) how you like to see the internal slot surfaces finished, Whether a clear coat or dark paint, I pre-finish the slot internal surfaces during the fabrication of the layered walls - i.e. after the spacers are glued in place, and before attachment of the final panel. 2) the pattern of grain matching and how you actually adhere the veneer to the box I've found paper backed sheet veneers works best with the iron-on glue method - yellow glue, velour nap paint or veneer glue roller, and clothes iron - particularly for the ease of trimming out the smaller openings we're talking about here. edit: I'm either too lazy / rushed or short on skills to veneer a speaker enclosure with real (natural/raw) veneers - without some type of backer (kraft paper, wood backed 2-ply) they're invariably very brittle, particularly in the cross grain direction My own practice is continuous wrapping of the 4 perimeter panels, with the front and back panels center matched from width of sheet. The sequence of overlapping is back/front*/side/side/bottom/top. *in the case of something like the prime Fonken style with large side chamfers, the front / bevels are one continuous piece, which can be easily folded over the 45` bevel with the iron. With the iron set to highest temp (linen), there's still a lot of working time. By using the to of the iron, you can quick distinctly outline the boundary of the slots (or rebated driver cutout) to be trimmed out. Yes, the slots will be too narrow for even 3/8" laminate trim bit, so careful trimming with sharp Olfa utility knife or veneer knife is required. That's where the scorch marks from the hot iron guide you. With some practice (30 or 40 pairs later) the driver opening and port slots can be trimmed out in a single piece - but you might want to start from the center and slowly trim to the demarked edge. You may need to revisit the edges with the iron during the trimming process, and follow up with fine grit PSA sandpaper (150-200 to start) on a wood file or thin stock of wood to dress up the slots, and free hand on edges of rebated driver cut-outs.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi Last edited by chrisb; 12th March 2010 at 10:01 PM. |
#434 | |
I think bondo etc would be the way to go, particularly if you're using the iron-glue method I'd say it goes without saying, but as I've said before "that" doesn't work - it is important that all edges are not rounded over before veneering - rather the opposite to a paint or fabric / vinyl / leather wrapped finish.
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#435 |
Chris: Where's a good source for veneers in Victoria?
Don |
#436 | |
thank you for your reply! The size of the dMar-ken is no problem for me. The loudspeakers I am using at the moment almost have the same size. Where can I find further information about this dmar-kens? Actually I couldnt find anything on the net, besides this thread. And: What is changed in Daves CHR-70eN driver? And if this special driver is required, where can I get it? greetings, Chris |
#437 |
At this moment in time, only two dMar-Ken designs exist, and neither are generally available - aside from a passing reference on the Planet10 website to the Alpair 7 version, this thread is all the information there is to find (other than the plans themselves, which can only be had by agreement with Planet10).
CHR-70eN is just the EnABLed version of CHR-70 - I haven't heard it, so I can't say whether the sound is markedly different, but the design itself will work fine with both first and second generation CHR-70's, with or without EnABL. CHR-70eN is available from Planet10 Hi-fi. Last edited by TheSeekerr; 13th March 2010 at 11:29 AM. |
#438 |
if you want a small cabinet, I would suggest my "Black Beauty" (4 liters GHP)
#439 | |
As I stated earlier in my listening impressions the amplifier choice and sources are very important. Thus far my old Phillips console SE 6BM8 (ECL82) receiver is the best out of class-d, Sanken powered SS, and Nakamichi "Stasis" receiver. Methinks the SE tube amps may ultimately be the best. I need to try my McCormack with them, but feel ultimately it would be at best a compromise. When I get a chance to listen to the big SS amp, I'll post my comments here.
#440 |
somewhat earlier in this thread, there was the subject of which amp. I mentioned that the best I heard my Black Beauties was with a tube amp, but that I did not remember which.. I did some digging and asking: it was a 6W EL84 pushpull amp (DIY of course).
| need great smd cap for audio application | jsaggio | Parts | 1 | 11th September 2007 03:41 AM |
| CV4014 and 5650 - any audio application of these tubes? | cm | Tubes / Valves | 0 | 18th January 2007 12:03 PM |
| Additional application for audio amps... | ashok | Everything Else | 8 | 17th August 2005 08:20 AM |
