#401 |
dMar-Ken70 progress picture:
![]() Nothing very exciting yet, but now that I've got a few of the tricks down, the second box will go together pretty easily. |
#402 |
Thanks Nanook.
#403 |
frugal-phile(tm)
Always helps to have lotsa clamps...
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#404 |
That's what's slowing me down - those are all the good clamps I have, so it's preventing me building the second box.
Notes for those who have built Onken's before: you'll note that the outer walls seem longer than strictly necessary - they are, but only because the bloke I had cut the timber got lazy and cut 12 backs instead of 4 backs and 8 sides. Doesn't matter, they'll get lopped off. Further note: using a nailgun (and glue) to build up the side wall assemblies saves a lot of time and clamps
#405 | |
frugal-phile(tm)
dave
#406 |
please consider my previous post as a guide only, of course. I'm not trying to persuade any to not build these great little speakers (well, not tiny, but pretty small). The Mark Audio drivers in modified form are quite critical of edgy sounding electronics and sources, and wiring, and...
I imagine the stock ones are more so, as EnABLing smooths out a lot of "edginess". I am not trying to play "audio snob" to any, as those who know me know that I am not, nor am I driven by the cost of a particular component to consider it to be "good" The comparison to the MS Avant 906i loudspeakers is accurate though. I suspect any design using the CHR-70 drivers (whether stock or EnABLed, or is it eNabled?) will be critical of all that is in front of them in the audio chain.
stew ☮ -"A sane man in an insane world appears insane." |
#407 |
Hey Dave, I've got a new project for you - the uMarOB-70
![]() Construction takes only seconds - indeed, everything you need is in the box. Bass response could be said to be a bit thin, in much the same way that water is a bit damp, but even like this these drivers are very involving. I was only going to set them up downstairs to break them in, but they appear to have ended up on my desk
#408 | |
#409 |
Yeah, when they're shipped they're supported in the box by a bit of folded cardboard - add a bit of tape to keep the cardboard box-shaped and screw them in with the supplied self tapping screws and you have something that sounds damn good for the invested time, if not for the money
#410 |
Any way you can PM me about being a beta tester for these Dave? I have a few pairs of CHR-70's that need a home, just sitting on a shelf mocking me. Anyway, PM me in private if I could be in the running.... Peace and keep well.
What was that?... I can't hear you I have a line array filling my ears. |
| need great smd cap for audio application | jsaggio | Parts | 1 | 11th September 2007 03:41 AM |
| CV4014 and 5650 - any audio application of these tubes? | cm | Tubes / Valves | 0 | 18th January 2007 12:03 PM |
| Additional application for audio amps... | ashok | Everything Else | 8 | 17th August 2005 08:20 AM |
