Old 8th February 2010, 04:55 AM   #341
Nanook is offline Nanook  Canada
Nanook's Avatar
or ya could always set up a threaded insert on the back (from the inside), and use a suitable length bolt to couple the back of the driver to the back of the box. Just don't over-tighten
preiter: nice looking boxes (and not a bad table either).
stew -"watch out where the Huskies go and don't you eat that yellow snow"--Nanook died of starvation 8 mos after the movie was made
Old 8th February 2010, 02:26 PM   #342
italynstylion's Avatar
^That's a wonderful idea. Might look a little funny though.
www.StereoClarity.com
Old 9th February 2010, 11:59 AM   #343
Nanook's Avatar
Default recall Michael Green...
...of "Room tunes" fame?
essentially he did the same thing using knock-down furniture connectors, and tightening or lossening them. The furniture connectors connected the opposite sides of the enclosue, thus a "tunable" speaker.
Old 9th February 2010, 12:29 PM   #344
MJK is offline MJK  United States
Originally Posted by Nanook View Post
or ya could always set up a threaded insert on the back (from the inside), and use a suitable length bolt to couple the back of the driver to the back of the box. Just don't over-tighten.
I had somebody come to my house once with a speaker that had a nice brass bolt through the rear wall pressing on the back of the driver's magnet. It was a really solid heavy duty cabinet with an 8" full range driver. Unfortunately when I ran some sweeps to measure the electrical impedance, it became clear that the bolt and the back of the driver were "rattling". You could not get enough linear compression between all of the stiff parts to keep everything in contact. Any small motion of the driver's magnet unloaded the bolt and caused a loss of contact. The impedance plot was very hashy, back off on the bolt so it was not touching and it cleared up. I am not convinced that this is a good idea.
Old 9th February 2010, 02:30 PM   #345
Whenever I use the bolt through the cab method I cut a wooden "disc" which is placed between the bolt and the magnet. A small hole holds the end of the bolt and the the disc provides extra support area on the back of the magnet.
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 10th February 2010, 04:19 PM   #346
markaudio's Avatar
Hi Guys,
This particular idea has just been brought to my attention. Please note the following:
NONE of the Markaudio drivers are designed to take a positive stress load on the rear of the chassis, in particular the motor assembly (back-plate).
This practice needs to be VERY carefully controlled to avoid the risk of distorting the driver. This practice could result in the driver's power-train being pushed out of alignment if you get it wrong.
Cheers
Mark.
Last edited by markaudio; 10th February 2010 at 04:40 PM. Reason: additional info.
Old 10th February 2010, 07:04 PM   #347
planet10's Avatar
Actuallty this is also true, althou perhaps not as dramatic, with pressed steel baskets & even cast baskets. You do not want to stress the basket.
A bolt also concentates the force, Andrews suggestion of a force spreader is a good one. I'll stick to holey driver braces thou.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th February 2010, 06:58 AM   #348
Ian444 is offline Ian444  Australia
I cut up thin cardboard shims from a manilla folder and glue them against the brace with PVA, each shim is around ten thou (0.25mm), usually I need 1 or 2 or 3. Then mount the speaker while the glue is wet, making sure there is no glue between the back of the speaker and the last shim. Seems to work well. With 10 thou at a time, you can get it just right.
Ian.
Old 11th February 2010, 07:19 AM   #349
planet10's Avatar
That is essentially the technique i use when a holey brace is a little shy (not often) except i'll just use a glue stick.
dave
Old 12th February 2010, 02:44 PM   #350
When I built my Alpair 10 OB's, I Glued a 1" thick Oak "Puck' to the rear of each driver, with a threaded insert at its center and used this to "Magnet Mount" the drivers. It would be easy to bring a threaded rod out of the puck with a locknut, two fender washers and a spring and "load' it against a brace such as the ones that dave uses!
Just a thought.
Pete
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Phil Townsend
need great smd cap for audio application jsaggio Parts 1 11th September 2007 04:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 01:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 09:20 AM
Page generated in 0.13907 seconds (79.77% PHP - 20.23% MySQL) with 11 queries
