#21 | |
#22 | |
Which did you get the 70's or the 10's? |
#23 | |
The enclosure will be a dual chamber reflex that I mentioned above but I'm thinking of a little bigger, 9-10L. This will move the frequency of highest ripple down from 100Hz to in the 50's. I have only limited space on my desk, including vertically, so I need to work some numbers before I finalize the dimensions. I also have to see what BB-ply is available locally. I think I'm going to be able to use just one 4x2 handy panel, if available. I also need to pick up some port material (aka. plumbing pipes) and a properly sized hole saw. I'll try to remember to take pics. |
#24 |
Scott, Just wondering if you or Dave, and Dave you can answer this one also, have either of you thought of a BVR with two CHR-70’s per side?
I’ve done three test boxes some not optimal due to them being available already built at home but as it stands the ported alignment in a 15LTR cabinet tuned to 50Hz sounded stellar. Huge soundstage, detailed mids and highs and a bottom end that makes the FE127 sound lifeless. In room I’d say I got response down to the mid 30’s to low 40’s and with decent levels also. Figure it this way, with two a side they have much better transient attacks and a much more clean less fatigued or strained sound at higher volumes. Sealed they sound amazing and with this alignment they seemed much more controlled but with the sacrifice of extension, they are 8LTR sealed and to be honest don’t remember where the roll-off is as this was merely a test. And my whole reason for this thread is to design a speaker that can stand on it’s own without the need for a dedicated sub in most reasonable sized rooms, true? Sealed out…. I also attempted a single sealed driver (8LTR) and a second CHR in a OB on top of the cabinet. These had a magical almost eerie air to them, but only worked well at lower volumes as I had a hard time controlling the open baffle CHR70 from over excursion at higher volumes. Properly Bi-amped and EQ’d to prevent the excursion issues it would be a great design, but alas also needed a sub. So as it stands a ported design is where I’m headed and to me the best option if a BVR. Now without the knowledge or math required to figure out a BVR design on my own I ask the entering question and say Scott or Dave any ideas? I’m very happy with the Mark Audio drivers and wouldn’t turn down a chance to try anything new they may offer. Well worth every cent these little guys cost, trust me you’ll be amazed, peace and happy listening.
What was that?... I can't hear you I have a line array filling my ears. |
#25 | ||
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#26 |
Probably.
OTOH, like Dr Strangelove, I have a plan... |
#27 |
I just ordered 5 pairs of these for a simple surround system. I'm excited to get them in!
#28 |
i just got a pair of CHR70s and proceeded to put them into a 7ltr front slot BR that i had previously used for the CSS FR125 .
after a couple hours of playing some bass heavy track for burn in, I took a listen and yup, they're truly very nice. Compared to the FR125, the CHR70s are louder, had more detail and better highs. I like these and will choose them even if they have the same price as the CSS FR125. |
#29 | |
Nice! That makes me even more excited to try out the ones I ordered! What are those enclosures tuned to? Where do you think your low end starts to roll off? |
#30 |
the port's tuned to 55hz
there's definitely usable bass down to 40hz (in my smallish room) |
| need great smd cap for audio application | jsaggio | Parts | 1 | 11th September 2007 03:41 AM |
| CV4014 and 5650 - any audio application of these tubes? | cm | Tubes / Valves | 0 | 18th January 2007 12:03 PM |
| Additional application for audio amps... | ashok | Everything Else | 8 | 17th August 2005 08:20 AM |
| Page generated in 0.13084 seconds (80.77% PHP - 19.23% MySQL) with 11 queries |
