Mark Audio CHR-70 Application Thread
Old 16th May 2009, 03:13 PM   #181
italynstylion is offline italynstylion  United States
italynstylion's Avatar
Default Re: Re: Re: Re: italynstylion
Originally posted by gychang
where can I find the detailed drawing/scale for this?
gychang
Dave posted it here... http://homepage.mac.com/tlinespeaker...map-130409.pdf
Old 17th May 2009, 12:59 PM   #182
human.bin is offline human.bin  Italy
which is the simulated frequenct response for the chr-70 in the lotus, any graph? except for power-handling will it change much using one or two drivers?
congratulations, i really like the design, i'm already ordering a pair of drivers
Old 31st May 2009, 08:07 PM   #183
liasom is offline liasom  United States
liasom's Avatar
Default CHR-70 Nearfield
Got my pair of CHR-70 drivers from alpair-usa.com. 61 bucks and really nice! Thank you, Mark.
It's enclosure time. Need to do some cutting and gluing and finishing. But I can't make up my mind.
Requirements are for nearfield use at my PC workstation with a NAD 7225PE receiver as power AND in keeping with the spirit of Mark's reason for developing these drivers--low budget and simple. So a pair of CHR-70s is all that is going to be used. I need to keep the enclosures to a reasonable size since they'll be on my desk. Ah, a pair of Lotus would be great in that corner office I covet, but that is not in my reality right now.
I've modeled enclosures at 10 liters BR tuned to 51 Hz and sealed 9.5 liters. Both with appropriate damping material. I know each type of system have their advantages and disadvantages, but nearfiled is new to me. I'll probably never drive the system to high SPL since it is nearfiled.
I really don't want to build both. I know I could compromise and build the 10 liter BR enclosure to use for both and experiment (seal the ports or not, adjust the stuffing...) but I'd rather settle into a decision before that to keep this simple.
So, your opinions are welcomed on what type of enclosure would be best for nearfield use. Sealed and BR enclosures are the only types I've ever built, I've never built a system for nearfiled use--so those two facts may be a constraint as far as keeping this simple. Also, I promise I'll document the build (when I make up my mind and actually start) for anyone else looking for this kind of nearfield solution.
Mike
"Twelve." --Dr. Nikolai Zubritsky
Old 31st May 2009, 08:14 PM   #184
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
if you have the space for the 10 liters, buid that and stuf the port according to your taste... if a smaller would suit yr desk more, you could try the 4 liter closed with high pass cap that I built (on page 5 of this thread)
Old 31st May 2009, 10:01 PM   #185
liasom's Avatar
Default Add to post 183 (CHR-70 Nearfield)
Thanks, Henkjan. Your post reminds me that I forgot to mention that I plan to build the enclosures and then measure the system frequency response after placement at my desk. I have a dual monitor setup so the right channel speaker will be closely sandwiched in between two large flat surfaces--one straight in front of me in between the two speakers and one outside the right speaker angled toward my right ear--and I know that will have an effect on frequency response.
So, regarding appropriate filters. I'm hoping that the loudness contour on the NAD 7225PE will work as a sort of el-cheapo BSC if I need that. Regarding adding components for BSC or contour filters, I'm hoping they will not be needed, but I'm willing to go to that expense if the result is that I'll gain a significant improvement in sonic quality.
Mike
Old 1st June 2009, 11:45 AM   #186
Henkjan's Avatar
what do you use as source? the PC? then you could probably do all the EQ your heart wants....
Old 1st June 2009, 06:03 PM   #187
dede is offline dede  France
Hello,
What is to your point the smallest closed enclosure that i could use for this driver ?
Anthony
Old 1st June 2009, 06:13 PM   #188
Henkjan's Avatar
if you apply a condensator as I have done in the BlackBeauty design, than you could go down to 2 liters (at the cost of some low end output)
Old 1st June 2009, 07:09 PM   #189
Old 6th June 2009, 10:44 PM   #190
HareBrained is offline HareBrained  United States
HareBrained's Avatar
If anyone is interested in EnABL'ing their CHR70, Dave and a few lucky other Canadians have begun listening to an EnABL'd pair in a sealed enclosure and their comments are posted in this thread about FR drivers for a SE amp. They're very positive about the improvement in SQ.
I think I'll start looking for a woofer to pair with my CHRs after they're EnABL'd.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
