Old 26th April 2009, 07:41 PM   #141
Corian is relatively heavy considering its "plastic". It is very dense but not as heavy as granite. Lots of colours available. Machines easily but makes a mess. I have used it to make a tube amp chassis among other things. You can use Cynoacrylate adhesive "Crazy Glue" for bonding, just make sure the surfaces to be bonded are smooth and adding a little moisture to the bond helps, I usually just exhale on the surface to be bonded then add the glue. Of course as Chrisby wrote there are the "correct" industry type adhesives that are usually used but the "Cyno" holds fairly well but I would not use it for something that my life depended upon
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 26th April 2009, 10:05 PM   #142
Geek's Avatar
Originally posted by italynstylion
Lunch or launch? One is scary and the other.....terrifying
Depends on which one... the fierce lion Hannibal could do either, depending on his mood
Old 27th April 2009, 04:13 AM   #143
Dave or Italynstylion do you have a cut sheet available for version 2.0 ?
Old 28th April 2009, 09:01 PM   #144
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
I have made some more pictures of the Black Beauty mini monitor
Old 28th April 2009, 09:02 PM   #145
Henkjan's Avatar
Old 29th April 2009, 02:06 AM   #146
italynstylion's Avatar
Very elegant Henkjan!
Cambe, I don't have a cutsheet worked out. I just started with the cut sheet I had made for 1.0 and then trimmed things as I needed.
Dave, I think a pair of v2.0 can be made out of 1 sheet of 4x8 wood. The left and right sides can be made out of the width of the sheet easily. The back plate can be made out of the upper section of the wood now that the rear of the enclosure is shorter than 48" high. Just don't screw up either of the 4 side panels because you can only get 4 of those out of a single sheet of wood. I learned that the hard way.
Old 29th April 2009, 03:03 AM   #147
tresch is offline tresch  United States
Henkjan, on the Black Beauties, there, very tidy woodwork! In fact, I'm curious exactly how they're assembled, because I can't seem to find any seems anywhere, at least not anything that would indicate 16mm thick panels. Are they all miter joints? Any in-progress construction pics?
Old 29th April 2009, 06:41 AM   #148
Henkjan's Avatar
yes, they are miter joints. what I did was lay out the panels on the floor (outside up) then tape it together with what we call "painter's tape" (the paper type tape) flip it over, apply normal white wood glue (spead it out with a brush) and then close the whole thing, apply some more tape where needed, let it dry for 15 minutes, remove the tape and clean any excess glue, and done. (then sand and varnish of course)
I had the panels made by a pro woodworker, he used a CNC router to make them the trick is to make the angle of the miter just a bit 'lean', so that the outside is certainly tight together
Old 29th April 2009, 06:52 AM   #149
Henkjan's Avatar
not from this build, but here are some from someone else's project, I think you'll get the idea from that...
Old 29th April 2009, 09:27 AM   #150
Awesome!
I was thinking about doing something just like this, recently, but hadn't thought of the tape idea. Thanks for the pics and everything
need great smd cap for audio application jsaggio Parts 1 11th September 2007 03:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 12:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 08:20 AM
Copyright ©1999-2013 diyAudio
