Mark Audio CHR-70 Application Thread
Old 24th April 2009, 05:53 PM   #131
italynstylion is offline italynstylion  United States
italynstylion's Avatar
Version 2.0 with the modification that Dave suggested. With the top ballast removed they become a lot less top heavy and I don't know if they will even need a base. I've got some sanding to do today and I'll test their stability later as well.
Old 24th April 2009, 06:18 PM   #132
speakrsrfun is offline speakrsrfun  Canada
speakrsrfun's Avatar
Your making me jealous Italianstylion, with my current project load of 4 LM3875 monoblocks and 2 F5 amps I'm likely to get these cabinets started in I don't know, never LOL.
I think I'll omit the second driver in mine at first to see what we get, then if I feel I need better power handling I'll add the second. I have visions of building my mother a pair of these as a gift, so the extra two drivers could come in handy yah dig....
They are kinda cute don't you think? LOL...
Good job ItalianStylion I look forward to your review after a full breaking in... Peace and keep well.
What was that?... I can't hear you I have a line array filling my ears.
Old 24th April 2009, 06:22 PM   #133
chrisb is offline chrisb
Even with sand or other heavy ballast material in the lower cavity, these will still be very tippy - I'd suggest a base plate at least 10" wide.
If you can find a local countertop shop that works with granite or synthetic quartz, it shouldn't be too hard to talk them out of a sink cut-out (amazing what a case of brew can get you on a sunny Friday afternoon)
kinda burnt out - taking a break
Old 24th April 2009, 07:04 PM   #134
What a fantastic idea! I'll see what i can find locally. Immediately I'm having trouble coming up with ideas about how to attach that to the bottom of the cabinet but I'm sure I could come up with something.
Old 24th April 2009, 11:00 PM   #135
VictoriaGuy is offline VictoriaGuy  Canada
If you have a cat around this is especially true. It's amazing how much tipping force they can generate when they launch themselves from the top of a speaker, or stretch up and lean on one. I had to patch a 1/4" deep dent when my (tiny) cat jumped off a Bose cabinet and launched it into the wall.
Cheers
John
Old 24th April 2009, 11:16 PM   #136
^^Just one of the many reasons why cat's are not good pets.
Old 24th April 2009, 11:56 PM   #137
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Careful when you come up for a VI diyFEST. One of our 10 cats may lunch on you.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th April 2009, 06:40 AM   #138
dave
Lunch or launch? One is scary and the other.....terrifying
Old 26th April 2009, 07:19 PM   #139
Funny- Dave, Scott Dunn & I were discussing this just yesterday afternoon. It might take a 2-4 (aka 2 dozen box), but the same shop should be able to drill a few through holes, and you'd attach to the enclosure with either a KD furniture assembly bolt, or even truss head wood screws. Don't worry about counterboring in the stone - PSA felt or rubber feet will raise the base plate higher than the head of the screws.
Now, if you wanted to get carried away and install spikes of some type, then things get a bit more interesting. In which case Corian or similar solid surface material ( also likely to be available from many countertop shops) can re relatively easily worked with using carbide woodwork tooling, and for non-structural work, can be glued with either white PVA or standard epoxy resins, as opposed to the proprietary adhesives that require special mixing/application guns. A few years ago, I made some Corian platters for my Rega turntable - all the machining was with hand rounters and a simple circle jig.
And depending on which gets to your lap first, Dave & Ruth's cats might well launch and lunch on you. They're a bit schizophrenic - can't decide if they're feral or domesticated (the cats that is)
Old 26th April 2009, 07:23 PM   #140
ROFL at the cats comment....
How heavy is corian? Do you think that would work well? I have a friend on another forum that might be able to get some. He recently posted a thread about it. I might have to hit him up.
Mark Audio CHR-70 Application ThreadHide this!Advertise here!
need great smd cap for audio application jsaggio Parts 1 11th September 2007 04:41 AM
CV4014 and 5650 - any audio application of these tubes? cm Tubes / Valves 0 18th January 2007 01:03 PM
Additional application for audio amps... ashok Everything Else 8 17th August 2005 09:20 AM
