T/S parameters measurement questions
Old 1st April 2009, 03:28 PM   #11
GM is offline GM  United States
GM's Avatar
Greets!
You're welcome!
Right, and now that you have a grasp of series resistance and since this is a 'FR' driver app, what you'll probably need to tonally balance the driver over the widest practical BW is some form of baffle step compensation filter (BSC): http://www.quarter-wave.com/General/..._Articles.html
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st April 2009, 04:09 PM   #12
IG81 is offline IG81  Canada
IG81's Avatar
Originally posted by GM
Greets!
You're welcome!
GM
I might consider BSC, but since I almost always use graphic equalizers **dodges rocks** and the speakers may move from room to room or to other houses, I might leave it alone.
Old 1st April 2009, 04:22 PM   #13
GM's Avatar
Just so long as it's not a cheap, low res, noisy one......... I switched to them in the early '80s when dbx came out with one that was ~transparent in a ~112 dB efficient (in-room) horn system.
GM
Old 2nd April 2009, 01:45 PM   #14
IG81's Avatar
Hi GM,
Thanks again for all the info. I'm now all done measuring my driver's parameters.
I finished last night by building a 5.25" I.D. cubic box to measure Vas. To find the volume of air trapped by the driver alone, I filled my driver's cone with rice and found the volume in ml with a measuring cup. I concluded that was the most accurate method I could easily use, what with the cone having a curved taper, whizzer cone...
Except for Qes, and incidentally Qts, which were 0.86 and 0.71 on manufacturer's sheets, all T/S parameters ended up being very close.
Fs = 70Hz
Re = 6.8ohm
Qms = 4.04
Qes = 0.49
Qts = 0.44
Vas = 8.72
n0 = 0.60%
SPL = 89.8dB
Thanks for the n0 and SPL formulas, they are not something I ever came accross searching the web and forums. I'll be hanging on to all that valuable info. This is my first speaker project, but probably won't be the last!
Cheers!
Old 2nd April 2009, 07:07 PM   #15
GM's Avatar
Greets!
You're welcome!
Thanks for sharing, can't have too many measured specs, especially of 'as built' designs (hint, hint).
GM
(PS: I use sugar as it helps to 'sweeten' the sound. Do it on a Deep South summer day and it gets downright 'syrupy'. )
Old 2nd April 2009, 08:07 PM   #16
IG81's Avatar
(PS: I use sugar as it helps to 'sweeten' the sound. Do it on a Deep South summer day and it gets downright 'syrupy'. ) [/B]
Hehe...
Rice isn't the best at taking a consistent ammount of space and at packing in a predictable manner, but it looks like it did close enough.
I'm reconsidering the BSC circuit, having just remembered of Rod Elliott's (ESP) design for line level, adjustable, passive (or active) BSC circuit. It will do away with the gripe I had with a fixed correction level and give me a good excuse to get one of these nice little Hammond aluminium project enclosures!
Oh, and 4.7ohm will do just fine to get my Qts up ~0.69 and still give me ~87.5dB @1m @1W.
T/S parameters measurement questionsHide this!Advertise here!
speaker measurement questions Josephjcole Full Range 35 3rd June 2005 04:19 AM
Driver parameters measurement Eccu Multi-Way 0 27th January 2005 10:17 AM
Speaker Parameters Measurement metal Multi-Way 1 3rd July 2004 08:43 PM
Dipole sub parameters questions A3rd.Zero Multi-Way 6 29th April 2004 04:10 PM
