Old 28th March 2009, 06:16 AM   #1
Default My Glass TB871 Build / Discussion
Hello All,
If any of you have been following all my random threads all over the place I finally found stuff I can work with. My matched drivers have arrived from Dave at Planet 10.. He ships fast and packages it really nicely.
Anyhow, I found a glass bottle at IKEA. It has a internal volume of 1.5L and the glass is slightly thicker than standard wine bottles. I am planning to stuff this with fibrefill and mount the drivers in the opening. It will be completely 100% sealed.
Now my questions are whether the slightly smaller internal volume would affect my sound quality / frequency response (I believe padded can reduce volume by 10%?) also, would epoxy be a good mounting glue or silicone be better?
Thanks for following. I'll post pics.. hopefully once I get everything in place.
Old 28th March 2009, 07:15 AM   #2
frugal-phile(tm)
planet10's Avatar
Glad to hear the drivers arrived.
The 1st 871S drivers i ever saw were mointed in 1 litre boxes... you might not get the most bass possible out of them, but they'll be fine, Stuffing can get you 10-30%, but too much will tend to degrade the sonics,
I wouldn't use anything to attach them that you can't somehow get them out. If you aren't going to affix a small baffle to screw the drivers in with, then silicon seal would be my 1st choice.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th March 2009, 05:19 PM   #3
alright, I think I'll go with the 1.5, lightly stuffed. Going to find a plastic / hard rubber baffle to fix it with.
Old 2nd April 2009, 08:54 PM   #4
Alright, my glass tubes/bottles are ready at 1.8L, they're a little over the 1.66 vas of the drivers. I think I'll need a HPF at approx 80hz. what value of capacitor will I need?
thanks
Old 2nd April 2009, 09:15 PM   #5
Speakerholic
Cal Weldon's Avatar
The Fs is 110 Hz no? That means your impedance is around 12-14 ohms at 80 Hz so about a 200 mfd cap for a first order. Are you sure you want it that low? Are you using the notch filter shown?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd April 2009, 09:24 PM   #6
wow. you're wayy over my head. no, no notch filter at this time, this is my really simple budget speaker =) maybe i'll add it in later if I feel I need it. I guess I could go a little higher at 95 or so, I just don't want to lose any of it.
Old 2nd April 2009, 09:44 PM   #7
frugal-phile(tm)
planet10's Avatar
Trying to do a passive at that frequency is very difficult as that is right near system resonance. Better to put a cap in front of the amplifier.
dave
Old 2nd April 2009, 09:46 PM   #8
badman is offline badman  United States
Custom Title
badman's Avatar
dave
Seconded. Harrison labs sells some products for this if you want adjustable/removable.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 2nd April 2009, 09:47 PM   #9
you mean put a cap in line with the input signal before the amp?
Old 2nd April 2009, 09:50 PM   #10
frugal-phile(tm)
planet10's Avatar
Yes. I'd try it without 1st.
dave
Discussion on what materials to build speakers out of planet10 Construction Tips 834 1st October 2011 07:41 PM
DIY 5.1ch Glass DAC? ak_47_boy Digital Source 6 23rd October 2006 05:34 PM
Anyone ever build a glass cabinet? Javachip Multi-Way 14 23rd May 2006 03:27 PM
Page generated in 0.09560 seconds (79.73% PHP - 20.27% MySQL) with 11 queries
