What do you think ?
I'm thinking of crossing it at 200hz (either 12 or 24db). I've seen a comment by lilmik "imho opinion the 166e has a little bit better resolution and the highs are a bit better. " (in reference to comparing the 166e to the 167e) Any audio difference between FE166 and FE167 Your opinion ? Norman |
#2 |
frugal-phile(tm)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I'm seriously contemplating that design.
Partsexpress "Black hole" and some fill, good to go. What components would a passive 6db of baffle step be ? maybe I'll try the passive line level filter, but I doubt it. Think it would work with lower z inputs like solid state amps? http://www.bottlehead.com/loosep/S.E.Xy%20speakers.html The driver impedance goes up a bit, so passive baffle step between amp and driver would become a smile shaped response, helpfull for our low volumes. The f3 is a squeek under 200hz. .25ft3 = qtc .577 To me, that design would be lacking in midbass, or even midrange and bass without any baffle step. Then again, if you are used to the sat/sub sound, that's your perogative. 200hz crossing to 2 x 15's, that'll make you dance !!! Norman |
#4 | |
frugal-phile(tm)
dave
#5 |
Here's the sealed box sizes I get for FE166e.
Qts = .21 fs = 50hz Vas = 45.11liters = 1.59ft3 Qtc .707 sealed Vb=.154 ft3 F3=Fsb=168 hz Qtc .577 sealed Vb=.243 ft3 F3=175hz F6=131hz (estimate) F9=87.5hz (estimate) Here's a quick link to crunching sealed box numbers..................... http://www.carstereo.com/help/Articles.cfm?id=26 I'll recrunch tomorrow at work, but these numbers look about right. Norman |
#6 |
I believe what Dave is refering to (he certainly doesn't need any guides to designing sealed boxes -something he's rather good at
#7 | |
frugal-phile(tm)
I have a 7 litre curved PE box, 2 unused plate amps, lots of spare woofers, but someone went and bought that 2nd set of FE166 putting this project on hold. dave PS: i am working to get a bunch more sets of measured numbers up here: http://planet10-hifi.com/measured.html
#8 |
Ah !!!!!!!!!!!!!!!!!!!!!
Thanks guys !!!!!!!!!!!!!!!!!!!!! I know it takes an act of congress to get things changed in a large company. It's a shame that fostex doesn't grab 1 out of 100 drivers and test them to make sure specs are current........................ Seems like the 166e in that .25ft3 parts express boxes may move to the front of my projects to do................ Thanks for the footwork planet10. Your intellectual property is valuable to many of us. Someday I look forward to some of your phase plugs. Norman |
#9 | |
frugal-phile(tm)
PP de rigor for any of the whizzer cone Fostex. dave
#10 |
"PP de rigor for any of the whizzer cone fostex"
PP I assume is phase plug/ What's de rigor mean ? |
| Kickbin, 80-200hz flat? | Wisounds | Subwoofers | 1 | 12th August 2009 03:46 PM |
| Looking for good bass to 200Hz | hugobors | Multi-Way | 20 | 30th July 2006 10:08 AM |
| 200hz sub | regal | Subwoofers | 2 | 9th January 2004 02:38 AM |
| Any suggestions for a subwoofer that can go up to 200Hz? | malisz | Subwoofers | 10 | 4th May 2003 03:39 PM |
| Page generated in 0.11084 seconds (80.18% PHP - 19.82% MySQL) with 10 queries |
