Well as most of you know, building two pairs of speakers at once is a lot quicker than building them separately. With that in mind I intend to build my own next pair of speakers along these which are being built for my father.
Here's what I want to build: A 2" full-range driver in an sealed cab responding to the 100-300Hz area which will be supplemented on the low-end by a small subwoofer a separate cab giving me response down to 40-45Hz. I can't install sketchup on my lappy due to windows sucking so I'll have to illustrate what I mean on the OH's mac when she's not looking. Here are my two preliminary driver choices: http://solen.ca/pdf/tangband/w51138sm.pdf http://solen.ca/pdf/tangband/w2852sh.pdf It looks like crossing these two over at 400Hz would be good? I'm thinking both cabs will need to be ported. I'd like front-firing because I don't have much room to space cabs from the wall with.
Wherever you go there you are. |
#2 |
Here's a pretty crude sketchup...
#3 |
400hz seems fine.
The "fast" system is gaining popularity. I suggest you cross the drivers where the baffle step -3db is. Perhaps have the baffle be 11" wide (f3 = 400hz). I wouldn't port the 2" driver, seal it for excursion ctrl. I'd play with a pa active crossover until you are sure of crossover points and levels at the volume you listen at. And a 24db will keep the .2" driver cleaner or less harsh I'm entertaining the w2-803sm for a small 4 unit mini array crossed at 200hz. I like 200hz@24db LR crossover point. To me it keeps the mids in the full range driver. A 6.5" is the cone area I like / need (dual 4" drivers). I tend to occasionall listen louder for movies. Norman |
#4 |
frugal-phile(tm)
From what i've seen, except for the alpairs, bandors, & jordans the 3" drivers do a better job than the 2" drivers.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 | |
the attached foto is from a system I completed a couple of years ago, the TB W2-800 and the W5-876 cross over at ~500Hz, where the baffle step helped set the xover frequency. |
#6 |
Very nice Henkjan. How much bass do you get from that woofer?
#7 |
an impressive amount considering the size. I had it tuned to 55Hz in 4 liters BR. it's the classical "Q: can you turn off the subwoofer, so I can hear the bass of the small thing? A: the sub is off..." in this size the bass is not very deep, but powerfull and only with stuff like 5 string bass or organ you'll want deeper bass
if you have the room for a larger box, put 2 in a TL and they realy shine, with nice deep and clean bass |
#8 |
Cool beans!
#9 | |
frugal-phile(tm)
We are quite chuffed with its performance, FF85KeN + SDX7 sealed, PLLXO at ~333Hz, The assymetrical slopes in the XO (2nd order on midtweeter, 1st order on woofer) help with BSC, There are a huge number of potentially good combos for FAST these days. dave
#10 |
Speakerholic
What is the FAST system?
| TABAQ TL for Tang Band | Bjohannesen | Full Range | 323 | 8th May 2012 05:11 AM |
| Tang Band W3-593SF vs. Tang Band W3-926SD | Zaputh | Full Range | 17 | 5th June 2009 11:37 PM |
| Tang Band MTM ? | wrenchone | Multi-Way | 11 | 21st November 2007 06:39 PM |
| 8 x 12 Tang Band | troystg | Subwoofers | 3 | 2nd February 2007 03:37 AM |
| Tang-band 2-way (W3+W8) | haffe | Multi-Way | 10 | 31st January 2007 11:11 PM |
| Page generated in 0.10142 seconds (80.88% PHP - 19.12% MySQL) with 11 queries |
