Diminutive full-range on a beer budget needed.
Old 22nd March 2009, 09:42 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Default Re: Re: the brick
Originally posted by G
The 871S is no longer available.
I have a stash that is larger than i'll be able to use.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd March 2009, 09:49 PM   #22
G is offline G  United States
G's Avatar
Default Re: Re: Re: the brick
dave
The only thing off with the 3" Bamboo is the vas. It's .01 liters too much so I would imagine that the dimensions of the cabinet would have to be changed. I love that little cabinet. Is there anyone that would be kind enough to model one with the W3-1364SA as the driver?
Gavin
Old 22nd March 2009, 09:55 PM   #23
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Originally posted by raypalmer
... But if you could calculate the TL for this driver that would be awesome!
can you give a link to the FE103 datasheet (I'm lazy...), this link is to another design...
Old 22nd March 2009, 09:57 PM   #24
Henkjan's Avatar
Originally posted by kristleifur
What T/S parameters would you try to find a match to, in another driver, for the box to look similar?
In other words, what are the most significant T/S parameters for the size/shape of your simmed box?
I'd say fs, qt, vas, BL... but rather compex, best is to run it throug my excel sheet to see if it gives similar dimensions
Old 22nd March 2009, 10:18 PM   #25
HareBrained is offline HareBrained  United States
HareBrained's Avatar
Hold-on... damping does not significantly slow down the speed of sound. Further the TL in the MArk Audio plans is an ML-TL so isn't in Martin's tables. ML-TLs are shorter for the same tuning. You are assumming that the line is tuned to Fs -- a good trick to get more bass, particularily with a small driver like the CHR, is to tune the box higher than Fs. So the shorter line is better explained by it being an ML-TL tuned above Fs. Given that there is essentially no damping in the box already, this makes a lot more sense.
dave
Originally posted by Scottmoose
Right. http://www.quarter-wave.com/TLs/Damping_Coefficient.pdf
Note that even with quite high stuffing densities of 0.9lbs ft^3 of dacron (which is higher than required for many ~aperiodic lines) the attenuation is nothing like approaching the kind of massive reduction in the s-o-s suggested above. Only about 18% of the way in fact.
As Dave points out, an MLTL is not a TL in the strict sense of the word. It's a highly resonant line, with some resistive loading to lower Fp; the little damping is present merely to attenuate the higher harmonic resonances while leaving F0 intact.
It was my understanding that a ML-TL (mass loaded transmission line) used a TL form but a much smaller "open area" or an actual port, which is not the case with the Pensil which is a line with an equal open end. Everything about the Pensil points to the QWTL. I'm obviously missing something. Perhaps you could provide a link that would identify the distinction differently so I could understand why the Pensil is not applicable to MJK's tables.
Old 22nd March 2009, 10:32 PM   #26
frugal-phile(tm)
planet10's Avatar
An ML-TL is a TL with a restricted terminus. The Pensil line is 90 x 130, the terminus is 78 x 130. That is a restriction. Not as dramatic as on some, but it still counts.
dave
Old 22nd March 2009, 11:21 PM   #27
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Sorry Henkjan that link I posted was completely wrong:S
This is what I meant to link you to
Wherever you go there you are.
Old 23rd March 2009, 03:47 AM   #28
AdamThorne is offline AdamThorne  United States
AdamThorne's Avatar
Originally posted by loninappleton
I thought of these too since they are getting some play on the forum.
Well, I've searched "LKO-120WFF" and "299-280" and "Peerless India" but it looks like I'm going to have to ask Lon (or anyone else) to point me in the direction of other discussions of these drivers.
Looking forward to improved search after the forum upgrade...
Old 23rd March 2009, 05:01 AM   #29
loninappleton is offline loninappleton  United States
http://www.parts-express.com/pe/show...number=299-280
Parts Express is in Ohio... no need to go to India as far as I know.
PE also has a forum for their stuff. If a more detailed data sheet is needed than the specs in the description, some leads may be gotten there. In their a-b-c measurement system, B is usually the size of the cutout needed.
More than that I don't know myself.
If the link doesn't work right, go to www.partsexpress.com
and put the number 299-280 in their search box.
Report back with anything else you need.
Old 23rd March 2009, 05:48 AM   #30
dave
Barely smaller, and no length to it. I'll defer to your knowledge but I don't see how it can have a difference at 1W.
Diminutive full-range on a beer budget needed.Hide this!Advertise here!
Recomendation needed, small cheap full range. internecine Full Range 26 27th May 2009 08:36 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
First DIY Single-Full-Range-Driver Help Needed GregGC Full Range 19 24th February 2004 06:13 PM
MTM Design needed on a budget kRaZeDcHiCkEn Multi-Way 41 29th September 2003 04:59 AM
