Is this a really dumb idea
Old 15th March 2009, 02:12 AM   #1
kimobuddy is offline kimobuddy  United States
Default Is this a really dumb idea
a biamped wide bander mated with a woofer/sub and an active crossover?
Old 15th March 2009, 02:17 AM   #2
raypalmer is offline raypalmer  Canada
raypalmer's Avatar
Well, no. Not if you're up to the task. I know I wouldn't be!
Do you have any particulars in mind yet? I'm curious to hum and hah over a sketch up
Wherever you go there you are.
Old 15th March 2009, 03:15 AM   #3
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
that is done quite often. Called an (active) FAST.
I'm listening to a set like this right now (FF85eN + SDX7eN = called Tysen)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 15th March 2009, 03:32 AM   #4
TerryO is online now TerryO  United States
TerryO's Avatar
dave
Dave,
I had to leave last summer before you got the Tysen hooked up, how did it sound?
The crossover you soldered up, did you end up modifying it or was it right on?
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 15th March 2009, 04:34 AM   #5
frugal-phile(tm)
planet10's Avatar
They sound REALLY good. XO worked just fine. We have been playing with a buffered version to give a wider range of choice for the HF amp.
dave
Old 15th March 2009, 05:56 AM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Default Re: Is this a really dumb idea
Instead I would do 2way active, crossed above baffelsteploss(300-500hz)
Besides, crossing the wideband driver higher you will achieve much better power handling
I plan to use Tangband 6.5" and 4" ti, both underhung and passive xo, may use a small ribbin on top
It will be an omni design, and I will use a plastic sewer drain tube
sometimes we know very little, and sometimes we know too much
Old 15th March 2009, 06:01 AM   #7
frugal-phile(tm)
planet10's Avatar
Tysen
Old 15th March 2009, 04:46 PM   #8
901Fixer is offline 901Fixer  United States
I think this is a great idea and is how I am gonna run my Aiko's. Fullrange is really at a disadvantage in the lower frequencies so the addition of a sub/mid-bass woofer really helps. Bi-amping allows for the most desirable type of crossover so coloration is minimal.
Old 15th March 2009, 05:00 PM   #9
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Tysen
Very nicely done and I like this idea. I will have to explore this possibility myself. The lack of low end response has been the stumbling block for me as far as full range goes.
Old 15th March 2009, 05:24 PM   #10
TerryO's Avatar
I've heard the Aikos at Dave's and thought, along with Kevin Haskins, that it was an absolutely splendid, top-notch speaker for vocals and acoustic instruments. OTOH, there certainly was a lack of the lower registers that really need augmentation. I agree with you that a subwoofer/lower mid woofer that is capable of extending into the lower mids would certainly help flesh out, what is otherwise a phenomenal presentation.
Best Regards,
TerryO
Is this a really dumb ideaHide this!Advertise here!
An idea! Fully balanced TDA1541A DAC idea. Please comment! cartman Digital Source 8 17th July 2007 08:18 AM
My latest dumb idea herm Multi-Way 11 29th October 2006 01:03 PM
Dumb Zen V4 Question Panelhead Pass Labs 4 26th April 2003 04:15 PM
Help me, I feel dumb. BAM Subwoofers 7 17th January 2002 06:53 AM
