To run without crossover, with bass aid from an Eminence Alpha 15 or 2x Peerless SLS-315, or similar woofer(s) for about 30-150hz.
Requirements: -High efficiency (95dB and up) -Very linear (also in the HF) -Low price (pair or quartet must not go over 400€, exceptions possible but not by much) -Available in Europe (please consider european price) Possible to run two in series if cheap enough, to raise SPL.
The response of the inner ear extends to at least 200khz - Dr W. Tempest |
#2 |
Eminence Legend 875 from Spectrumaudio/Breitbandlautsprecher might be worth looking at, if its available at all
Seems to roll off smoothly around 8khz Cone screams fore coating |
#3 | |
So far, it seems that only some Fostex (FE166E and bigger siblings) meet cost requirements, breaking that, there are a few Lowther and Supravox which could do the job, but it's a pity to cut their low end (I do need 30hz).
#4 |
Possible candidates are:
-Fostex FE166E (single driver per speaker), rolles off at around 18k, 95dB -Jordan JXR6 HD (2x in series), the most linear response I have ever seen. It should go past 20khz. And in OB should rolloff nicely on the bottom octaves. It may be a little expensive (needing to raise sensitivity)
#5 |
Maybe the Ciare HX201 with compensation like it is usually done with the Visaton B200.
#6 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
The quality of the midrange is for me of paramount importance. If the plan of using a single widerange (for mid andhighs) wont work, I'll have to go 3-way. In that case I have seen a Goodwins 12" that works marvelous up to 10k or more. It seems that a wideband with nice response is always very unsensitive, there must be a correlation of sort
#8 | |
Checked. 96dB sens, 5-9 Ohm impedance are acceptable, paper cone (good, its my fav), from 9k up needs EQ. I can do it digitally but i'm trying to avoid at first. Price is also good due to Ciare being an italian company. Overall is a discrete driver. Someone has a link to an OB project that used it? For compensation you mean bass compensation or EQ?
#9 |
I answer myself about the Fostex.
The 166E seems to whizz, the 167S should be a better choice. I saw it paired with just one Eminence Beta 15. I'm trying to get more information about those speakers.
#10 |
Added:
-Audio Nirvana Super 8 AlNiCo (which would stretch my budget of a good 100 bucks) -Audio Nirvan Super 12 Cast frame -Audio Nirvan Super 10 Cast frame in this order of preference.
| Wideband Midbasses | Taterworks | Multi-Way | 9 | 19th April 2008 01:18 PM |
| Which wideband/FR sound great with Dean Martin? | freddi | Full Range | 2 | 4th January 2007 10:47 PM |
| pics of DIY 3-ways w/ 1354 wideband | 3-LockBox | Multi-Way | 0 | 1st August 2006 07:44 PM |
| Wanted,wideband Front Load horn to go with I.B. | mikee55 | Full Range | 0 | 10th February 2006 12:18 PM |
| Just a little note : When you wideband amp oscillates at 200KHz and you dont know why | sonnya | Solid State | 6 | 1st August 2003 06:08 PM |
| Page generated in 0.11120 seconds (79.82% PHP - 20.18% MySQL) with 11 queries |
