diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Modifying Magnets JX92S (http://www.diyaudio.com/forums/full-range/140392-modifying-magnets-jx92s.html)
_henry_ 13th March 2009 05:50 PM
I saw PARTSEXPRESS now carry neodymium magnets, which comes with different shape.
I wonder if its good to change the ferrite magnets from JX92S with neo magnets with config like FOCAL farraday rings?
cheers
planet10 13th March 2009 07:18 PM
If you don't know the answer to that, then you are not likely to be able to do it... even someone that really knew what they were doing (and access to a serious shop) would probably end up destroying at least a couple drivers before getting one that worked (and not likely with magnets from PE).
dave
CSS/XBL 13th March 2009 08:14 PM
I'm aware of one Jordan OEM who removed the shielding but even that was serious work and not for the faint of heart.
Bob
_henry_ 14th March 2009 02:30 AM
:D
Good advice.
i knew a friend back home who's crazy about neo magnets
he change lots of speaker magnets, including the jx92s but unfortunately i didnt hear them in proper way.
he did with focal style of magnets, with 5pcs 25mm neo magnets stack together and did 5 of them for the jx92s.
but even he didn't know the proper calculations for it :D
so i guess you are on the spot, dave :D
soongsc 14th March 2009 02:36 AM
Bob
I took a shield off using a screwdriver. Was a JX125.
planet10 14th March 2009 02:44 AM
JX125 and JX150 aren't sheilded... it is just a plastic cover. I have a JX150 where the cover just came off on its own
dave
Scottmoose 14th March 2009 11:18 AM
A well built driver then. :angel:
Resources saved on this page: MySQL 18.75%
