I have 2 pair of WR125ST's to recycle from an earlier project. (Fatally low WAF!)
Is it feasible to mount them together (flat-to-flat) in a BIB? What adjusted values should I enter into the BIB calculator if I wanted to do this? I'm assuming that the calculated "z" would actually be the centreline ie where frame touches frame. Note that a helper tweeter or supertweeter would be needed. I'm just assuming that that's not a big issue once the basics are sorted. Can anyone assist? For that matter, has anyone tried this? Thanks Doug
A speaker-builder's parable: "That burned down, fell over, then sank into the swamp. But the fourth one stayed up. And that's what you're going to get, Lad, the strongest castle of all." |
#2 |
Same as any other time when you double the number of drivers.
If paralleled, Vas & Sd double, Re & Le halve. If wired in series, Vas, Sd, Bl, Re & Le all double. |
#3 |
OK. Thanks Scotmoose.
Next question ... Is it better to orient the pair side-by-side or under-and-over? Side by side would mean, I think, that the actual line length would be the calculated value, but the under and over arrangement would perhaps "smear" the positioning? Would this "smearing" be detrimental? Or perhaps beneficial, if the FR response was smoother? cheers Doug
#4 |
Over-under would be preferable. You'll have to bring the tweeter in quite early to avoid combing effects.
#5 | |
5000Hz? 4000Hz? I presume that having it clearly above the 300-3000Hz band is desirable. Doug
#6 |
Assuming you can get away with it, yes (although our critical hearing BW is 200Hz - 4KHz &, preferably an octave either side
#7 |
Speakerholic
Hi Brisso,
Scott designed a double horn box for the two WR's as well. Something to consider and it's an easy build. It's called the Calhoun. I would recommend running the drivers as I have to remove any problem with combing and to act as a BSC. You have to squeeze every ounce of goodness from those drivers so I chose that route. I am not disappointed. |
#8 |
Speakerholic
The previous use of those divers I was not happy with no matter how much I played around with them, mostly as a result of having the two drivers on the front.
#9 |
Doug:
I've heard Cal's " 'houns", and if you have the space to allow for experimenting with the tricks that the side firing drivers' soundstage / imaging allow, these work great. You will need a tweeter, and IIRC Cal used an inexpensive Audax soft-domed wave guide unit?
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#10 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| A twin-WR125ST tower concept | Brisso57 | Multi-Way | 2 | 11th August 2008 10:58 AM |
| Where to cross in a supertweeter with 2 WR125ST's? | Brisso57 | Multi-Way | 15 | 19th December 2007 08:23 PM |
| WR125ST's - 2 x matched pairs | mrpopgun | Swap Meet | 8 | 10th February 2007 05:42 PM |
| New WR125ST TL design | Timn8ter | Full Range | 43 | 16th June 2005 07:36 PM |
| WR125ST quadpole? | audiobomber | Full Range | 23 | 24th May 2005 10:23 PM |
| Page generated in 0.11205 seconds (80.41% PHP - 19.59% MySQL) with 11 queries |
