i am planing to build a Bipolar Line Array with 2 or 3" Driver (8 or 16 on each side). Now my Questions. 1. Did anybody build such a line Array? if yes what was his experience? 2. What is the best wire for the drivers? (combination of seriell/parallel?) 3. what is the best way to regulate the loudness of the backspeaker? (for example with a Fostex R100?) Thank you for your help. best regards Josef |
#2 |
I'm thinking you're going to need major Eq for a start due to the severe lobing issues of running FR drivers in a line. That should bring the vanishing HF back up. You may, or may not hear the combing through the upper midrange. Some people do, some don't. Depends on how suseptable you are to such things. The Hass effect does come into play; depending on the design, I can sometimes live with it, TBH, although it's usually better not to run into such issues in the first place.
#3 |
I have to agree, xover design will be a migraine. Then after it's built (migraine #2) you'll have to go back and tune the xo endlessly.
All that being said; your FRBPLA (or Frabpla) proposal interests me to death, and if you do design and build one successfully I'll need you to post your schematics so I can copy it
Wherever you go there you are. |
#4 |
c'mon guys...we are in 2009
XOVERS are handleded easily with digital equipment such as Beringher DCX ..and it is not even expensive so other than work to tune it out, there is no building migraine here jpetek: i have no experience with bipolar line array but may i ask why are you interested in building such a system ? |
#5 |
Would that it were as simple as you make out.
The wiring isn't anything per-se to do with an XO, it's more to create a reasonable impedance, and possibly, to assist in power-tapering the line. For e.g., if no power tapering is required / desired, then, if 16 drivers were used, I'd simply divide them into 4 groups of 4 drivers, where the individual units within the groups are wired in series, then simply parallel the 4 groups. You will need some form of Eq, digital (preferable) or otherwise, to compensate for the problems caused by the output of the driver's lobing, and creating destructive combing. This will start to occur when the centre-to-centre spacing of the drivers exceeds 1 wavelength of the frequencies being reproduced & becomes progressively worse as frequency increases. For example, assuming a 3in c-t-c spacing, then this will be from about 4.5KHz. You can Eq the progressive HF attenuation this causes up, but you can't do much about the severe nulls / roughening of the response. As noted, the Hass effect can negate some of that, but it will rather depend on the design, and also, the way you happen to listen -we all know how some things bother some people more than others, so YMMV as always, but tread with caution. |
#6 |
Why bipolar? Isn't the major benefit of a line array its directivity and cancellation of room reflections? (Heard one. Have build one for testing) If that bipolar thing is used to gain more "imaging" or whatever you could gain that through a "standard" line array with a matching crossover points and maybe a little EQ. I don't think you need more Energy from "behind", after hearing the "Lightning" from Monacor, there is plenty.... But thats your try.
(I did build a line with 3", you'll need a tweeter line too. Sim it: http://www.pvconsultants.com/audio/radiation/vpr.htm) -Micha |
#7 |
The trouble with active/passive arguments is polarization. The "passive people" usually argue the worst case scenario, and don't always know that the Behringer can do things such as multiple simultaneous EQ. The "active people" tend to not think through the xover in the design, assuming the 'puter will fix it. This can be disappointing, especially when one finds the upgrades necessary for the Behringer to quietly and accurately process a 24/96 data stream.
I don't know anything about line arrays, but it is cool we have all these tools. As a third option, forget that some sound cards can become the crossover on a computer driven system. I played with this approach several years ago, so I don't know the current state of the art. |
#8 |
I decide not to go to a bipolar Linearray. It is too complicate. I decide to build a Linearray with 16 NEW Bandor drivern per side. Doreen from Bandor will build the new type for this project. I will keep you inform. best regards Josef |
#9 |
bye the way for this project I need a fast subwoofer which works till 200 Hz.
Any idea? regards Josef |
#10 |
I'm thinking you're going to have lobing problems. Still, you might get away with it, on-axis.
Well, you won't get away with a single sub -sound is increasingly directional from about 72Hz upward, so you'll hear sound coming from a different location from that point up to the XO frequency. Twin subs would be mandatory, & you'd probably be better off with woofers rather than subs, which usually don't go higher than 100Hz with much grace. A couple of quick examples would be to take a look at the CSS SDX7s, or if you wanted something larger, some of the Eminence range of drivers (Beta / Gamma 15 etc). |
| Line Array's for HT use | rickp15 | Planars & Exotics | 7 | 25th April 2008 02:17 AM |
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| t-line subs for a DIY line array | tom1356 | Multi-Way | 17 | 28th December 2002 12:15 AM |
| Page generated in 0.10852 seconds (78.92% PHP - 21.08% MySQL) with 10 queries |
