new FR 8's Wild Burro Audio Labs
Old 7th March 2009, 01:28 PM   #21
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Thanks for the link to the BIB page pj... good luck to you!
If you send me a pic of your Burro BIB i will link it from the BIB site back to yours.
Godzilla
Old 7th March 2009, 03:10 PM   #22
dzzmiller is offline dzzmiller  United States
Were at a point now where the real differences between FR drivers are frequently about dispersion and distortion, not frequency response.
I've been playing around with the Jordan JX92S. I think they are great, except for off access high frequency.
Myself, I don't think that FR is the place to look for econo drivers. The "value point" is in two way, IMO. I'm surprised daily that people will do huge cabinet builds with BB around a single $45 driver.
But again, I had no reason to be negative about the Burro venture. It's fun to play with this stuff, and it can't hurt to have more people making drivers. My concern is too many FR cabinet design and not enough detail testing and thinking.
Old 7th March 2009, 03:32 PM   #23
Godzilla's Avatar
A few years ago it was the opposite. There will be more drivers and more designs coming. That's a good thing IMO because we can play around and discover new things.
I want a Betsy in an OB!
http://www.sonicflare.com/_audio_a2...images_side.jpg
http://www.toneimports.com/auditori...mages/svox3.gif
Maybe a Betsy can be used in a poor man version of the Solo Vox?
Godzilla
Old 7th March 2009, 03:58 PM   #24
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Why? If you've got the space, a good big cabinet is inherently less compromised than a good little cab & allow you to extract more from a given driver.
Old 7th March 2009, 05:14 PM   #25
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Locals are certainly welcome to stop by, so long as you aren't offended by unfinished plywood. Maybe this will be the spring I get the BIB's outside and finish them! My OB's are quick and dirty prototypes. I should make a decent looking set. Maybe once I get the tube amp done. It's my first point-to-point, and I'm drawing out parts layout as we speak. And if I could only get my turntable to run the correct speed . . .
Thank you all for the encouragement. 'Zilla, I don't know if you remember, but my first fullrange thoughts came from a discussion with you over at AA. Prior to that I was listening to some "budget" two ways. And of course, my BIB enclosures are something Scott sim'd early on in the BIB thread. One of the reasons I'm trying to keep the margin well lower than the industry standard is that I know you two, Greg, Dave, Eli Duttman and others have given me and others countless hours of free advice. I do want to do this as a member of the DIY community, not an outsider profiting from it.
All should feel free to share their thoughts about future versions of these drivers. I haven't asked for price quotes yet, but AlNiCo is a very real possibility. I'm sure I could order a few without whizzers, for example. Of course, the mass would be lower, and it'd be more of a midrange. There is a little more interest in the BetsyK than I expected. I may see about a version with lower compliance, but the Fs would go up.
pj
http://www.wildburroaudio.com
Old 7th March 2009, 07:24 PM   #26
freddi is offline freddi  United States
freddi's Avatar
re:future versions - could Qes lowered without upsetting the mid-treble balance? - that could reduce some enclosure's bulk - my pc is so messed up that won't run WinISD - here's what AJ thinks of BetsyK in 84 liters - not sure of AJ is good for BR (it does BIB sims alright)
alnico would be cool for BetsyA
Old 7th March 2009, 07:25 PM   #27
pjanda1's Avatar
I think cabinet building is, for many folks, especially young ones, the most intimidating part of speaker building. I can build a chip amp with some soldering tools, a drill and a screwdriver. Even a basic bass reflex takes a couple of saws, a couple of sawhorses, and some space where you can make a mess. Most lumber suppliers won't guarantee cuts to be closer than 1/8" to your spec, and that is not good enough to build a box. It is plenty good enough for an OB.
The idea here is to create speakers that anybody could build. Once folks get their feet wet and hear some diy speakers, I think they'll be much more likely to engage in more complicated endeavors, be they gigantic double mouth horns with fullrange drivers or multiways with double thick MDF sidewalls and tons of bracing.
Don't confuse entry level build or entry level price with entry level sound either. Used within their displacement limitations, I think that these will run with seriously expensive competition. Once someone is ready to move beyond an easy build, active biamping and helper woofers are possibility.
pj
Old 7th March 2009, 08:19 PM   #28
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Maybe that's why i got to where i am... i think the 3rd box i built was a Radford S90 clone.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th March 2009, 08:36 PM   #29
blumenco is offline blumenco  United States
Default Cheers,
Hi PJ,
It is good to see your drivers! I hope to hear a pair soon.
-Clark
www.blumensteinaudio.com
Blumenstein Audio - Handmade High Efficiency Full Range Single Driver Speakers from Seattle, USA Since 2006
Old 7th March 2009, 08:46 PM   #30
doorman is offline doorman  Canada
doorman's Avatar
Ditto: Good Luck to your venture!
Don
new FR 8's Wild Burro Audio LabsHide this!Advertise here!
Cal Audio Labs CL-15 bungelow_ed Digital Source 0 8th July 2009 02:21 PM
my first DIY project, the Burro/Boomer? ..of_letters Full Range 14 19th May 2009 09:07 AM
Invisible Audio Solutions from Emo Labs angeloitacare Multi-Way 2 23rd January 2009 06:18 PM
Another California Audio Labs CL-5 Question neddyboy Digital Source 1 7th October 2007 11:06 AM
Agape Audio Labs Hagto Tubes / Valves 0 5th May 2006 05:45 PM
Copyright ©1999-2017 diyAudio
