Hi all, I recently modified some old wharfedale pacific pi's somewhat similar to the brynn, but with different dimensions. Chrisb then said that I shouldn't call them brynn as they are not the same design. Well really I didn't call them the brynn, I only said they were similar. Now after running them for as long as possible before the first bake off of its kind in the UK I used them at said bake off and had some very positive comments and requests to make some for others. At the moment they are in a somewhat rough form but I will now be making the back thicker and changing the added on baffle to site the driver centrally. Drivers are FE126E by the way. Chrisb suggested a 5 Ohm resistor with the 126, what would that actually do, give more bass, less bass, less top?
#2 |
You're welcome.
#3 |
You're welcome.
#4 |
I designed Brynn.
#5 |
of course I should have recognized your name. maybe you could enlighten me regarding the 5 Ohm resistor.
#6 |
It'd make the thing work as it should.
BTW -when you say you might be making more, out of interest, do you mind if I asked what it is you're planning to do? I ask because it does mildly affect things from our POV. Knocking a couple together as a favour for mates = no worries. Selling as a cottage industry kind of thing = no worries either, we encourage it, but we do make a couple of minor conditions -see the Use of Designs page on the FH site http://www.frugal-horn.com/use.html -I see you've made a couple of minor changes, but none are fundamental to the design per se. Best Scott |
#7 |
I don't think I will be making them for anyone else, if I did they would only be for friends without the skill to do so. There wouldn't be any point in trying to make money from them, I don't think thats possible on such a small scale and with limited workshop facilities.
#8 |
Ain't that the truth.
Well for most of us anyway. Nothing personal; I had to mention it as a matter of course.
#9 |
I will post some pictures when they are finished, unlike my other builds these have only been modded, quite major mods I suppose but not worth documenting.
| Horn experts - Please help to determine optimal throat size for low-mid horn | pk | Multi-Way | 7 | 21st March 2010 05:31 PM |
| Single Driver Horn Base Port from Frugal Horn | EmergencyDpt | Swap Meet | 0 | 26th October 2008 01:24 AM |
| RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer | thekop-bkk | Swap Meet | 0 | 26th September 2008 03:55 AM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 05:06 AM |
| Page generated in 0.09388 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
