Internally Curved Austin Horn
Old 5th March 2009, 10:08 PM   #11
dzzmiller is offline dzzmiller  United States
Originally posted by kazoo
So to understand this, do you want a smooth horn path? Lately it seems that guys that have access to CNC machines are going for the layered look. So is it worth doing a smooth horn path or is the standard horn path out of straight panels just as good. The reason I ask is I am wanting to build the Dallas II speakers. I have had some 206e drivers sitting hear for a while. I modeled the speaker from the plans on Dave's site and there was only one dimension I was missing to have everything match the dimensions from the plans. I guessed on it and I think I have come close but anyway I also created a curve in the model to show a smooth horn path. I was going to build it using this smooth path. So I guess I am asking if its worth it to do the smooth path or if the path using straight edges is as good.
John
John, if you look at the Dallas II photos, the kerfboard implementation would not be hard to build. But if you don't want some curved exterior features, the square build only requires adding three curves. This shouldn't change dimensions.
I'm a bit confused by Ron's water analogy. The analogy to water is air, not sound. Is it safe to assume sound waves behave the same as flowing fiuids and gases?
Old 6th March 2009, 01:18 PM   #12
Also, I did read a comment from RonC that the Dallas II does does not incorporate his latest design thinking. Sorry, I didn't think to save the link.
There are a lot of designs of back-loaded horns like the Dallas. It might be worth looking at the most developed. Or use the available tools to rerun the numbers on the Dallas.
Internally Curved Austin HornHide this!Advertise here!
Blown fuse when power on without connections internally hew128 Digital Line Level 9 30th August 2009 04:18 AM
Austin 166 ed2000145 Full Range 4 15th May 2009 05:57 PM
Neopro5i - opinions on how to connect to internally topher_m Multi-Way 2 8th May 2009 02:18 PM
Frugal-Horn & Austin 126 lazyfly Full Range 2 2nd November 2008 04:19 PM
Austin 166's in Austin seanzozo Full Range 32 25th March 2007 03:47 AM
