How big does a sealed enclosure have to be in relation to a driver's Vas to be considered an infinite baffle enclosure? Is there a rule of thumb?
Thanks! IG81 |
#2 |
In the strict sense of the definition, infinite baffle IS a sealed box. That is to say, the baffle is infinite because one could not trace a path from the front of the cone to the rear; they are seperated. When you see what is commonly referred to as infinite baffle, it's usually a woofer that uses a household boundary (walls/floor/ceiling) to seperate the front wave from the backwave. A line could be traced from the front of the cone to the rear- through a doorway, down the stairs into the basement, etc.
I suspect your question could be rephrased as "In relation to Vas, how large does an accoustic suspension (sealed/IB) enclosure need to be to get the Q of the system close to the Qts of the woofer. Any rudimentary box modelling program (or even a comprehensive one, of course) can spit this number out with a little trial and error. Start at 1:1 box volume to Vas, and increase until you get close enough to satisfy your needs. Decrease to see the effect on the curve. Bear in mind that most people have varrying opinions on what sounds best when it comes to sealed box system Q. Low Q vs. high Q have their own set of drawbacks and advantages. |
#3 |
Yes, you rephrased my question correctly and thanks for the answer. I kinda ended-up answering myself by downloading and playing around in WinISD.
I was looking for a ~4-5" fullrange that fits a sealed box to make a low-Q IB, but those are hard to find, most have high EBP... IG |
| ESL in infinite baffle | hugobors | Planars & Exotics | 9 | 15th March 2008 04:22 PM |
| F200A in spherical steel infinite baffle enclosure | sharpi31 | Full Range | 10 | 3rd September 2007 11:59 AM |
| Help with infinite baffle. | Andrew S- | Multi-Way | 2 | 8th February 2006 03:53 PM |
| help w/ infinite baffle sub | HIPCHECK | Subwoofers | 5 | 16th December 2005 12:19 AM |
| Infinite Baffle. Best bet if possible? | Hybrid fourdoor | Multi-Way | 50 | 9th July 2004 08:52 PM |
| Page generated in 0.06831 seconds (71.89% PHP - 28.11% MySQL) with 10 queries |
