Hi All,
Can anyone recommend a good enclosure for the above besides those that's in diyparadise website ? I like Scott Moose Half Chang design but I guest it would not work without a redesign which I'm not qualified to do in the first place. thanks |
#2 |
'fraid not, it won't. It'd need a dedicated design & the main problem with the Corals is that they've been defunct for many years, and there are no specs. available, unless you can measure your own.
#3 |
Hi Scott,
Thank you for the reply. I've got some specs here which I'm told is quite accurate. Fo 54 hz Qms 7.312 Qes 0.52738 Qts 0.4919 Vas 60.319 L Would greatly appreciate if you could kindly advice. Thank you again |
#4 |
They might be. But they might not be for your own drivers after so much time has elapsed since Coral went belly up. And I'm loath to try to fudge something (& it would be a fudge anyway as the specs are incomplete) for these, you build it, and then find it didn't work because your own units either spec. differently, or have aged differently & so on & so forth. That's why I've never done a box for Corals, decent units though I gather they were.
#5 |
None of us are leaving this world alive. Enjoy it responsibly as you may. |
#6 |
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#7 |
Cheers Greg.
#8 |
Hi All,
Thank s for the advice & links. Hi GM, Is it ok if I e-mail you for some advice with regards to Folded ML TQWT design ? Thanks |
#9 |
Greets!
You're welcome! Why not here? GM
#10 |
Hi GM,
Thank you. Because I've got some idea about the speaker that I want to build but will only post it if I suceed. Many thanks again |
| Coral Flat 5 t/s | ballsingtripp | Full Range | 17 | 15th November 2009 09:46 AM |
| Coral Flat 6B's. 2 pairs. | nodiak | Swap Meet | 1 | 11th March 2008 09:47 PM |
| Coral Flat 10 | albertli | Full Range | 16 | 3rd August 2006 04:07 PM |
| FS: Coral Flat 6B drivers | harryz | Swap Meet | 0 | 2nd August 2006 09:16 AM |
| Coral Flat 6 question. | steenoe | Full Range | 4 | 29th June 2005 03:58 PM |
| Page generated in 0.10295 seconds (76.95% PHP - 23.05% MySQL) with 10 queries |
