Old 18th February 2009, 03:16 AM   #1
lumstar is offline lumstar  Canada
Default Speaker Efficiency
So I'm just wondering what defines an efficient speaker? How can I tell how efficient my speakers are? In the D class forum they talk about the fact that a Tripath amp can drive efficient speakers to relatively high volume levels. However, I don't know what defines speaker efficiency.
Thanks!
Old 18th February 2009, 04:11 AM   #2
gmilitano's Avatar
http://en.wikipedia.org/wiki/Loudspe...vs_sensitivity
Something to start you off
Cheers
Old 18th February 2009, 06:18 AM   #3
chrisb is online now chrisb  Canada
from above wikipedia citation
An unusual 3-way speaker system. The cabinet is narrow to reduce a diffraction effect called the 'baffle step'.
emphasis mine,
anyone, anyone, .... Bueller?
I read it on the internets, so it must be true
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 18th February 2009, 09:23 AM   #4
Scottmoose's Avatar
Ah, wikipedia. The font of all wisdom & knowledge.
Old 18th February 2009, 11:02 AM   #5
I trust that the old boys' club here at the Full Range forum has gone and fixed up the Wikipedia article?
Anyway, sorry for the OT:
In short, efficiency is a quantification of how many dB the speaker puts out with a certain number of watts.
Then, technically unrelated to speaker efficiency, but important in practice, some amplifiers like certain speaker impedances much better than others. Since you mentioned Tripath amps, most of them love 4 Ohm impedances, and only put out half as much power into 8 Ohms.
Old 18th February 2009, 11:40 AM   #6
Geek's Avatar
And still more accurate than most of the printed encyclopedia's out there
Speakers are all about tradeoffs. You can get really high efficiency, usually at the expense of bass and Xmax (linear cone excursion).
A speaker of same dimensions for example rated 95dB will sound just as loud with 1 watt as a common 85dB speaker will at 10 watts. BUT... the 85dB speaker may be able to go to 50Hz, while the 95dB one to 120Hz in the same cab.
Cheers!
Old 18th February 2009, 01:57 PM   #7
Scottmoose's Avatar
Originally posted by Geek
[B]
Tell that to the majority of naval historians out there...
Old 18th February 2009, 03:47 PM   #8
Is there a doctor in the house?
Hello, doctor - why does it hurt when I pe?
Old 18th February 2009, 03:47 PM   #9
That certainly clears things up! Thanks for the help ppl.
Old 18th February 2009, 03:59 PM   #10
Actually, on balance there's some good stuff in the article that could be considered a jr high school primer on the subject.
Horn Speaker Efficiency classAchap Multi-Way 2 15th October 2008 09:12 PM
Improving speaker efficiency?? mitchyz250f Multi-Way 8 23rd July 2008 04:25 AM
Speaker Efficiency cm961 Multi-Way 11 5th August 2002 08:18 PM
Speaker Efficiency Oz_Audio Multi-Way 1 6th July 2002 11:52 AM
Page generated in 0.10916 seconds (77.08% PHP - 22.92% MySQL) with 10 queries
