My DIY Phase Plugs - Page 3 - diyAudio
Old 23rd February 2009, 02:21 PM   #21
jadybug is offline jadybug  Canada
For what it is worth, has anyone been here speaker info, ie phase plugs?
http://www.mother-of-tone.com/speaker.htm
Jadybug
Old 23rd February 2009, 02:56 PM   #22
frugal-phile(tm)
planet10's Avatar
"Other speaker drivers that still employ paper cones AND paper voice-coil formers are... Fostex FE series ..."
Not all the FE series have paper voice coils. Further, the plastic compounds i add to the surfce of Fostex cones, makes them sound better.
Some of what this guys says makes a lot of sense, some just seems, IMHO, to be taking things too far.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd February 2009, 03:11 PM   #23
JC951t is offline JC951t  Taiwan
Does anyone knows if the extra surrounds that's
glued on Decware's drivers improves the bass
& sound of the speaker ?
Old 25th February 2009, 03:56 AM   #24
Default see other thread
I had a thread on making phase plugs called homebrew phase plugs and was using those 49 cent drivers from Pioneer mentioned above.
But this is about something else:
I was in the hardware store and saw some bullet shaped cap nuts with hex bases. These may have been for auto but I don't think so.
It has the cone shape and are bright chrome color. I can get the
manufacturer some other trip. But what I wondered was if you manage to get the right diameter for (it would have to be one of the
6 in ones like 167e) how would you ever get it _off_ if need be?
Same deal with the nut used by the thread starter. Those have to be
magnetized pretty strongly.
It is weird how when inserting the phase plug you can hear the
sound change as you are finding the sweet spot. I don't know if all that fiddling is necessary with a metal pp.
Old 25th February 2009, 05:22 AM   #25
RaphTube's Avatar
Default Re: see other thread
I haven't tried this, but what I would try is file out thick grooves in the base, so that it effectively sticks on little 'feet'.
-otherwise you could try gluing something (rubber washer, etc) to the base, to weaken the force.
-R
Old 25th February 2009, 05:23 AM   #26
RaphTube's Avatar
Default Get it off
- Why would you want to get it off anyway??
-R
Old 25th February 2009, 09:07 AM   #27
OzMikeH is offline OzMikeH  Australia
to replace it with a nice machined hardwood one.
Help some guys with funny hair bang two rocks together really hard.
http://athome.web.cern.ch/athome/LHCathome/whatis.html
Old 25th February 2009, 01:23 PM   #28
RaphTube's Avatar
yes!
-understandable
-R
Old 25th February 2009, 02:25 PM   #29
Well, I've worked with wood.
Lacking a lathe or knowing how to use one I've been using little wooden craft eggs (they should be in good supply again near Easter) and a piece of dowel both glued, then shaped to fit.
The brass ones really look good though.
Homebrew phase plugs
The Planet 10 lipstick tube suggestion is still the best but I haven't been to the Revlon (or other mfg) department to find a right item.
Old 26th February 2009, 01:48 PM   #30
For a different type of phase plug for horns there is this site of interest;
http://users.bigpond.net.au/ggoodacr...diy/plugs.html
Jadybug
126/127 Phase Plugs staggerlee Full Range 1 20th June 2007 02:59 PM
Phase plugs Lostcause Full Range 48 17th May 2006 06:26 PM
phase plugs Dave Jones Multi-Way 30 27th June 2004 10:15 PM
Phase Plugs levon Multi-Way 33 15th March 2004 12:11 AM
Copyright 1999-2017 diyAudio
