My DIY Phase Plugs
My DIY Phase Plugs
Old 20th February 2009, 05:58 AM   #11
RaphTube is offline RaphTube  South Africa
RaphTube's Avatar
Default my process
#7 - clean ALL debris out of center of driver
#8 - remove tape from gap
#9 - screw in new phase plug
#10 - Enjoy.
Now it wasn't all as easy as it looks. I ran into a few problems.
-but that why I'm doing these experiments before I get to my FE167e's.
I have not done any listening yet, but will do soon.
-R
Old 20th February 2009, 06:14 AM   #12
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
My DIY Phase Plugs
From that last picture, i'd suggest a plug that is fatter (so there is less gap) and longer (tip should reach to the top edge of the whizzer (at least))
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th February 2009, 01:26 PM   #13
RaphTube's Avatar
Default Cool
Thanks Dave,
I was wondering about the dimensions.
- I was also wondering about how drilling a hole down the middle would effect the magnetic field?
I assume the pro's outweigh the con's.
-R
Old 20th February 2009, 01:36 PM   #14
RaphTube's Avatar
Default Square??
Originally posted by yan6
I then used a lathe to get them smooth and square.
Ryan, I really don't know what I'm talking about here, but my intuition tells me that a squared-top/sharp-edge would be a bad Idea.
-Is there a non-cosmetic reason why you made them this way?
-R
Old 20th February 2009, 01:48 PM   #15
Magura is offline Magura  Denmark
Magura's Avatar
Default Re: Square??
It can't be any worse than this http://www.decware.com/newsite/DFR8.htm
.....and a hex socket is substantially cheaper than the 200$ they want for it
Not that either will work as well as a bullet shaped, or a mushroom shaped plug.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 20th February 2009, 02:40 PM   #16
yan6 is offline yan6  Canada
For the extra work involded in making a bullet or mushroom shape phase plug or the cost of buying some, I thought I would try the socket. I had read of a few people trying this with success and knowing of the decware design, I thought this cant be too far off. After some listening I have found that most of the midrange shout is gone and the sound seems much less directional. As far as I'm concered this has done it for me!
Gio, just by ear using the blink test cd, I can hear 31.5Hz no problem, but it is not quite full volume (with respect to the other tracks). 40Hz seem to be full volume. No sub right now, I'm not sure I need one.
Old 20th February 2009, 03:09 PM   #17
amp_guy is offline amp_guy  United States
dave
I agree mine have about the same clearance as the voice coil/pole piece. I didn't want to take the chance of metals chips getting into the gap so mine are fastened with a small amount of JB weld and positioned with shims till set up. never tried one of the mushroom shapes though.
Old 20th February 2009, 06:29 PM   #18
anybody seen Steve Deckart's new phase plugs?
vac tubes? yep thats right.
http://www.decware.com/newsite/DFR6.htm
I don't know about this one, seems to me the internals would resonate badly. But hey Iam not adverse to at least try it.
Old 20th February 2009, 09:39 PM   #19
frugal-phile(tm)
planet10's Avatar
My DIY Phase Plugs
Somewhere deep in my email, i have comments from a customer, that tried both the decware socket and my plugs. The sockets are back in his toolbox (i've not tried the socket -- getting it out after putting it in is not easy)
dave
Old 20th February 2009, 09:47 PM   #20
frugal-phile(tm)
planet10's Avatar
My DIY Phase Plugs
Me too... and we did find that. The idea is not original to Deckart (IIRC, either Cal's or Chris')... see the picture published in this forum post (ie Aug 05 at the 2nd annual Vancouver Island diyFEST (#6 21 aug 09)) at least a year before he released his new plug
http://www.diyaudio.com/forums/attac...amp=1125340084
http://www.diyaudio.com/forums/showt...940#post712940
dave
My DIY Phase PlugsHide this!Advertise here!
126/127 Phase Plugs staggerlee Full Range 1 20th June 2007 02:59 PM
Phase plugs Lostcause Full Range 48 17th May 2006 06:26 PM
phase plugs Dave Jones Multi-Way 30 27th June 2004 10:15 PM
Phase Plugs levon Multi-Way 33 15th March 2004 12:11 AM
Copyright ©1999-2017 diyAudio
