#11 |
Given the Alpair 5 operates well into the lower midrange, you probably won't need to get the drivers much closer than shown in the photo. My Jordan 2"/bass combination crossed at 500Hz and was about that distance apart. Sounded fine. The Alpairs will probably crossover lower. Besides, they need to be in their own separate enclosure (I assume, if like the Jordans) so you have to leave room for that.
I'd question the need for a supertweeter with them. The Jordan JXR6, which is similar, operates up to 30kHz. |
#12 |
another Super Tweeter? the alpair 5 can go to 30khz
#13 |
you're absolutely right colin.
so how do you did for the jordans? its jx125 and jxr6? can u share the pic and experience please? cheers |
#14 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#15 | ||
#16 |
if we put 2 Transmission Line in 1 Cabinet, similar like what B&W did with the Nautilus, let say the Alpair 5 on the top and Alpair 10 slightly lower that goes to the bottom maybe exit on the back
do u think this would be a good setup? |
#17 |
you mean a well damped TL for the Alpair5 to get a clean midrange (backwave gets caught in the TL)? nice idea... some creative woodworking required, but worth a try I's say
#18 |
frugal-phile(tm)
The sketch below is for our as-built Tysen with FF85 and sealed SDX7. The 1st concept had Jordan J6T/Alpair 5 ... i'm using the sketch to illustrate a possible approah to the double TL.
![]() The aperiodic TL on the top is a straight-forward high ratio aperiodic TL -- if needed it could be rotated so that the botton was parallel to the ground and the top was sloped down towards the back. What is a holey brace in the sealed box could easily be a TL partition. With Alpair 10, putting the driver on the front is probably a good idea. Further, to take advantage of optimum driver offset, i'd add an additional partition so that the back part of the line can be extended to have the terminus on the front/bottom. This should rotate the line sufficiently that the A10 will be near the bottom of the A5 TL. dave
#19 |
No one went for this (AP5+10) ?
Would have thought a 1st order Xovr would be really nice ?? Patrick |
#20 |
frugal-phile(tm)
This project hasn't reached the top of the queue (+ i still need to get a A6 woofer -- no pint in using a plain A10)
dave
| Alpair 7 - out of the bag | markaudio | Full Range | 16 | 27th November 2009 12:30 PM |
| Alpair 12 - also out of the bag | markaudio | Full Range | 23 | 23rd November 2009 03:48 AM |
| Alpair 10 wide bass driver and Alpair 10 Fullrange | _henry_ | Full Range | 71 | 15th March 2009 11:37 AM |
| Can anyone help TL or ML-TL for Alpair 10 | _henry_ | Full Range | 3 | 31st December 2008 06:31 AM |
| Considering JXR6 or Alpair 5 | timpert | Multi-Way | 0 | 4th June 2008 11:48 AM |
| Page generated in 0.09338 seconds (86.00% PHP - 14.00% MySQL) with 11 queries |
