I am looking to find some sort of extensive list for full range driver manufacturers. I find it extremely difficult on my own.
My parameters are as follows: 8ohm or higher, high efficency, and high Q rating (open baffle). I would prefer an impedance higher than 8ohm, but I would settle if required. Any and all information is appreciated. If you know of an online dealer, I would appreciate that too. |
#2 |
What size?
#3 |
8ohm or higher
6" or larger 95dB efficiency or higher (92dB for 16ohm) Frequency capable of around 45Hz I really would like to see as many options as possible. Because I don't want to find out 6 months later I missed a much better option. |
#4 |
There are a lot of full range drivers, with quite detailed info, on the site of this German distributor (if you don't know German, you can still look at the pictures): http://www.spectrumaudio.de/breitband.html Regards, Dirk |
#5 |
8ohm or higher
6" or larger 95dB efficiency or higher (92dB and up for 16ohm) Frequency capable of around 45Hz Costing less than $1,200 for a pair of drivers High Q rating making them ideal for open baffle |
#6 |
Getting 45Hz in an "honest" way means you need really large baffles. The Supravox 215 Signature Bicone comes into my mind. Nielsio is going to sell his ones because he wants to upgrade to something really expensive Thoughts on Supravox 215-2000 EXC or PHY-HP?
If you go the mainstream way of narrow baffle plus bass support almost any fullrange driver has a low enough Fs to allow any Qts. |
#7 |
Thats part of the trick. Finding reasonably priced speakers capable of low end performance.
There are plenty of other issues though. Whether it lack of online presense by manufatcurers, lack of a comprehnsive list, or lack of dealers. It's hard to find these drivers because of all this. But drivers exist that fit the bill. Hemp Acoustics, Senon, Moth Audio, etc. all make some. But even when you know who makes them it's still not easy. Hemp Acoustics has a website showing MANY models, but they provide no information on them. I can't find Moth Audio drivers anywhere. And I personally want to do all my homework so I get the best driver possible. But I need help since there's many roadblocks in the way. |
#8 |
Spectrum Audio in Germany have a 12" chinese SENON YD1256U
Could be interesting to try a pair in 2.5way, but may need supertweeter...and subs Fs/46hz, 90db, Qts/1.33...27 EUR Looks quite nice edit, a small 5-6" fullrange with a couple of "filler" woofers might be worth a try Supravox have some nice options Visaton have some cheap woofers, and in US maybe Goldwood Fore quality woofers MOREL may have a couple of interesting alternatives |
#9 |
Not all fullrange, but a good list to start
http://audiotools.com/drivers.html You can find lowther fullrange drivers for under $1200/pair http://www.commonsenseaudio.com/lowther.html the doc and projects are here http://www.lowtherloudspeakers.com/homeindex.html
surfing the 2nd harmonic ... @@@@ |
#10 |
Thanks for the ideas guys. Unfortunately not much help. The Lowthers disqualify themselves due to the Q.
The sad part is I have a pair of Visaton B200's in my closet. But their impedance disqualifies them. |
| No-Name full range Driver | ArjenShenzhen | Full Range | 13 | 18th August 2008 12:19 PM |
| Please help me expand my little list of subwoofer driver manufacturers | buggsson | Subwoofers | 7 | 11th July 2007 02:54 PM |
| Full Range Horn DIY Project List | ruerose | Full Range | 4 | 27th December 2006 08:51 PM |
| Full range driver for UK | bond | Full Range | 4 | 18th March 2005 03:30 PM |
| Full Range Driver | PassFan | Full Range | 4 | 18th November 2003 03:28 AM |
| Page generated in 0.11179 seconds (76.35% PHP - 23.65% MySQL) with 11 queries |
