Old 27th March 2011, 10:34 PM   #31
jannes is offline jannes  Netherlands
I've been eyeing these Conic's for some time, and now the Alpair 10 has been succeeded by the 10.2. Would it be possible to use the new drivers as drop-in replacements? Or will the cabinets need to be modified?
Old 1st April 2011, 09:16 PM   #32
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
I can't tell, because I gave the cabinets away, sorry.
to make optimal use of the gen2's deeper bass the best would be a different cabinet, but then again it might just sound great, maybe adjust the stuffing, in this cab (which were not originally designed for the Alapir10 in the 1st place)
Old 3rd April 2011, 06:49 AM   #33
Would acoustic foam like this be an alternative to sonofil for this horn? It seems like acousta-stuf will be very hard to use since it's not made in sheets, and the damping material has to be glued or stapled to the ceiling...
Acoustic Foam 1-1/2" 24" x 18" UL 94
Old 3rd April 2011, 10:25 AM   #34
Henkjan's Avatar
I'm not an expert on horns, but I guess it depends on where the damping material is, if it is "volume damping", so in the middle of the box I would guess it is not a good alternative.
I found no problems with the wool type material, just a few staples of a little glue on the wall is usually enough to keep it in place.
Old 4th April 2011, 03:26 AM   #35
My contribution: a slightly more detailed plan. I changed the measurements to inches and rounded when necessary. I hope they're close enough not to compromise the performance of the horn.
Driver inside of mouth of a folded conical horn ultrakaz Full Range 17 19th May 2009 05:56 AM
Midbass Conical Horn - Keele vs Hornsresp which is the better FR? steve71 Multi-Way 28 27th October 2008 07:35 PM
Compensation for Conical Horn Sheldon Multi-Way 1 11th November 2006 10:01 PM
Page generated in 0.08187 seconds (68.31% PHP - 31.69% MySQL) with 11 queries
