Conical Horn with Markaudio Alpair10 FR
Old 24th April 2009, 10:27 PM   #21
madawasca mike is offline madawasca mike  Canada
Default Guilty
Nothing to report, we're not ready yet.
Likewise, I have the VirtueOne. Using Vintage Mirage 450's which I just had refoamed and enjoying those with the Virtue.
I did wonder if Henkjan had any further refinements to recommend.
Old 25th April 2009, 09:00 AM   #22
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default Re: Guilty
Originally posted by JC Fardo
Did you flush mount the driver. That 9mm flange are really thick
in my test enclosure they are not flush mounted, if you want to you'll probably want to make the baffle thicker than 18mm.. what I plan to do is add a 9mm sheet of nice looking wood to the baffle (and some thinner of the same on the rest of the cab)
Originally posted by Barnhouse
.... May mate with a sub for the very bottom end but am a bit anti-sub has never managed to get them to sound "real".
only the very bottom end is where you might want a sub, e.g. organ. so maybe x-over at 70Hz or so, or just make the sub 'come in' where Conic stops. in either case, some sort of DSP for the sub will greatly enhance yr chance of success. I have not tried any sub with them yet.
no further progress here either. clearing out some other projects first, I'm drowning in speakers (to quote my wife)
Old 6th September 2009, 08:11 PM   #23
Barnhouse is offline Barnhouse  United Kingdom
A dumb question most likely, however...
Henkjan (or anyone), am I right to assume that the external width is 190mm and therefore in the plan above the sides are not additional width?
Thanks for your patience
Old 6th September 2009, 08:52 PM   #24
Henkjan's Avatar
yes, the 190mm is outside width, assuming 18mm thick wood
Old 18th October 2009, 08:02 AM   #25
weidok is offline weidok  Netherlands
weidok's Avatar
Originally Posted by Henkjan View Post
sorry, no updates yet... I did buy all the stuff I need to get my measuring gear working again (mic, USB-preamp, usb hub) so when i find the time and courage to install everything, I will post it here...
sorry !!!!
did you find some time
There is NoBox like NoBox
Old 23rd October 2009, 08:06 PM   #26
Henkjan's Avatar
haha, you know I have still a shortage of that.... but the measuring gear is working, so maybe this year
Old 26th October 2009, 02:12 PM   #27
Default inching ahead
Even dumber question than Barn's. Are the side pieces then mounted within/inside the 190mm front piece. Or another way to ask this is, what is the width of the internal slanting piece . It's either 190mm or 190 minus the 18mm x 2 side pieces.
Other wise I have the other pieces pieces all cut including the holes for the drivers and we will be in the shop in two weeks to assemble.
Old 26th October 2009, 03:40 PM   #28
Henkjan's Avatar
(190-2*18)mm
Old 26th October 2009, 03:53 PM   #29
Default 190-
Many thanks for quick reply. As I said we are mostly ready to move to assembly.
Old 17th November 2009, 06:52 PM   #30
Default Conic horn built
Having committed to a pair of "Henkjan Horns" at the beginning of the year, I finally get round to building the things in mid-Nov.
Structurally complete (in MDF, veneering still to do) and playing music for about 5hrs now I thought I had better post a couple of early impressions and perhaps spur others into action.
A few qualifications on the builder/listener are probably in order - my first horn project, no experience with bigŁ/$ kit, previous speakers were JX92s with a sub (both sealed).
Initial thoughts? Impressive. Everything I loved about the Jordan's (before little fingers poked the cones and damaged them!). Initial veil is starting to lift with break in and bass is coming on nicely.
I have a sneaky suspicion these will be winners.
Conical Horn with Markaudio Alpair10 FRHide this!Advertise here!
Driver inside of mouth of a folded conical horn ultrakaz Full Range 17 19th May 2009 05:56 AM
Midbass Conical Horn - Keele vs Hornsresp which is the better FR? steve71 Multi-Way 28 27th October 2008 07:35 PM
Compensation for Conical Horn Sheldon Multi-Way 1 11th November 2006 10:01 PM
Copyright ©1999-2017 diyAudio
